20 Most Recent
Sharp REGISTERCASH2CLRLCD2LN XEA506 PC Desktop Questions & Answers
I cannot connect my sharp
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?model=XE-A406
It took me a while to find the Windows 7 64-bit driver for the XE-A506, but apparently it is located under the XE-A406 version. Eventually, this one worked for me: but don't forget to run the program as administrator (properties - compatibility - "Run this program as an administrator").
By the way, the manual was a bit unclear on how to install the drivers (for me at least). This is the whole process that actually got it working in my case:
- Go to "Devices and Printers"
- Right-click the device under Unspecified - select "Properties"
- Select the "Hardware" tab
- Open "Properties"
- In the "General" tab, select "Change Settings"
- Select the "Driver" tab
- Here the option for "Update Driver..." should be available, open it
- Select "Browse my computer for driver software"
- Select "Let me pick from a list of device drivers on my computer"
- Press "Have Disk" (sometimes this option isn't immediately available, first press "Next" in that case)
- Select "Browse"
- Head to the location where the driver (*.inf) is downloaded, something like "Downloads\SHARP XE-A406_A506 SOFTWARE - 64bit\Sharp XE-A406_A506\Setup\program files\SHARP ECR TOOL\XE-A406506 Customer Support Tool\Driver\Win64" and select it
- Press "Open"
- Press "OK"
- Press "Next". The driver should now install.
And again, don't forgot to Run as Administrator when starting the software: without this, I still couldn't upload data to the device.
4/13/2015 4:10:25 PM •
Sharp...
Answered
on Apr 13, 2015
Sharp era420 not printing on left side
If its feeding paper but not printing, make sure that you are using the correct thermal paper and that there is no extra bits of paper stuck under the printing head. Otherwise it might need a replacement printing head. If its not feeding the paper at all, then make sure that the receipt is turned on.
WONT CLEAR TRANSACTION
More information required. Please provide the model number of the cash register and the transaction that wont clear?
