20 Most Recent
Life Science Bionet Cardiocare 2000 12 Channel Ecg Questions & Answers
My ECG machine is not
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
EKG / ECG Machines
The noise is because of the mechanics of the printer you have to open it and you will find one dashly is partially broken or not fixed so change it or fix it.
I have a problem in ekg bionet cardiocare 2000.
If you haven't solved the problem yet, most likely you will have to send the unit in for repair. When you first power up the unit the system goes through a self test. "light on then off then on again"
Low battery
When your dealing with a low battery message you can do many things like the following:
1- Replace the battery.
2- Check the voltage of the battery with a multimeter.
3- Disconnect the unit from the AC source and check if the unit continue functioning without the AC source.
