20 Most Recent
Energizer Eveready TUF4D1E 4D Cell Lantern Questions & Answers
I can't figure how to
I've owned this flashlight for years. In the comment above, ignore the
instruction to remove the rubber casing around the lamp area. Simply
grasp the whole front of the lamp piece (including the rubber cover), and
twist in a counter-clockwise direction to remove. Then squeeze
together the two black tabs and pull the battery compartment out to
replace the batteries.
8/22/2012 6:03:15 PM •
Energizer...
Answered
on Aug 22, 2012
Don't know how to replace the batteries.
I've owned this flashlight for years.Grasp the whole front of the lamp piece (including the rubber cover), and
7/27/2012 11:09:22 PM •
Energizer...
Answered
on Jul 27, 2012
This still doesn't help. how to you get the
I've owned this flashlight for years. Ignore the
7/27/2012 11:08:04 PM •
Energizer...
Answered
on Jul 27, 2012
My TUF4D1 flashlight does not have a twistoff cap
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out.
7/27/2012 10:53:57 PM •
Energizer...
Answered
on Jul 27, 2012
How to change lightbulb in hard case energizer flashlight?
Hello, Lori -
There is more than one style of Energizer Hard Case Flashlight.
- Professional Mult-Use Light
- Professional LED Task Light
- Spotlight
- Professional LED Inspection Light
- PivotPro Light
- LED Work Light
- LED Magnet Headlight
- Professional Rugged LED Headlight
Which one are you asking about?
Without knowing which model your question is about, I suggest you contact Energizer Customer Service and ask how to open your flashlight model to change the battery. This is the link to the Energizer Contact Us web page:
https://energizer.custhelp.com/
Best wishes.
7/1/2018 10:37:38 PM •
Energizer...
Answered
on Jul 01, 2018
Change the battery in the hard case
Start by unscrewing the lense cap retaining ring. Pinch and remove the clip from the negative (-) spring on the battery. Remove battery and slide new one in. Reconnect wire connector in between spring on the negative side of the battery. Note: some lanterns have a v'd plastic ear on the back of the reflector so when you go to screw the reflector back on, align the v'd ear with the plastic bar inside the case under the handle and slide it together until you can screw the retainer ring on.
11/21/2016 2:37:53 AM •
Energizer...
Answered
on Nov 21, 2016
Would like to know
That's the model number for the Eveready Rechargeable Torch, I think.
9/16/2014 12:52:54 PM •
Energizer...
Answered
on Sep 16, 2014
