20 Most Recent
Infinity Reference 611a Car Audio Amplifier Questions & Answers
System starts hitting and my
4 quick checks.
try lowering the gain on your amplifier.
check if your sub or subs are not making the amplifier run lower than 2 OHM.
check if the power cable is the right Gauge(4 Gauge) and the fuse is large enough for the amplifier. It should be slightly more than the fuse rating of the amplifier.
check to see if your ground is secured properly to the chassis.
dreamsystems
2/16/2011 7:17:28 PM •
Infinity...
Answered
on Feb 16, 2011
Need to know how to wire my system ...I have the
it all depends on what kind of box the mtx subs are in as far as wiring the subs. The best way would be take the speaker wire from both sub boxes and run the positive into the right positive then the negative into the left negative. and run 8 gauge wiring kit to the amp because 10 might be to small and 4 is to big 8 gauge is perfect for this amp.
7/28/2010 12:27:56 PM •
Infinity...
Answered
on Jul 28, 2010
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi,
if thats a dodge this might be it..
Re: Infinity Gold AMP Wire Diagram
Well I don't particularly care for
Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately:
Hartness 1:
[7] Left Soundbar Speaker (+) BR/YL
[8] Left Soundbar Speaker (-) BR/LB
[5] Left Front Door Spkr (+) DG
[1] Left Front Door Spkr (-) BR/RD
[9] Right Soundbar Speaker (+) DB/WT
[3] Right Soundbar Speaker (-) DB/OR
[6] Right Front Door Spkr (+) VT
[2] Right Front Door Spkr (-) DB/RD
[4] Power Amp Relay Feed DG/RD
Harness 2:
[05] Right Soundbar Spkr (+) TN/RD
[13] Right Soundbar Spkr (-) TN/BK
[06] Left Soundbar Spkr (+) WT/TN
[14] Left Soundbar Spkr (-) WT/BK
[11] Passenger Door Spkr (+) LB/RD
[10] Passenger Door Spkr (-) LB/BK
[04] Drivers Door Spkr (+) DG
[12] Drivers Door Spkr (-) LG/RD
[01] Power Amp Feed
[02] Power Amp Feed
[07] Power Amp Ground
[08] Power Amp Ground
The tweeters run in parallel off of the door speakers.... If I can help any more let me know.
-Mike.
https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
