20 Most Recent Nikon COOLPIX S6000 Digital Camera Questions & Answers
S6000 not saving one picture, then locking up
Your SD card may have a greater capacity than the camera can handle - check the max size in the manual.
6/9/2017 8:33:46 AM • Nikon COOLPIX... • Answered on Jun 09, 2017
How do you reset nikon s6000 to factory settings?
In the tool menu (wrench) you should be able to find this. Make sure you really want to do this before you reset the camera... you cannot go back after a reset.
4/2/2017 5:56:57 PM • Nikon COOLPIX... • Answered on Apr 02, 2017
FLIP MINI HD
You need a program to download your video go to youtube they will do it for you
6/3/2014 5:41:41 PM • Nikon COOLPIX... • Answered on Jun 03, 2014
FLIP MINI HD CANNOT DOWNLOAD FILE
check your settings (camera connetion settings and also the usb port settings)
5/25/2014 3:51:50 AM • Nikon COOLPIX... • Answered on May 25, 2014
My Coolpix s6000 just won't charge I bought a new
It sounds like one of two things. Either there is a short circuit in your camera that is draining the battery or the camera's battery charger circuit is not charging the battery. There are a few things you can do. You can send the camera to Nikon USA for repair (look on the Nikon website for the address the closest repair center). The other thing you could do is buy an inexpensive external charger for the battery and see if the camera works for a resonable period after charging the batteries externally. Adorama.com carries both the Nikon and off brand models and will give you the best price. It that works, you know that the camera's battery charging circuit is the problem. If that is the case, you could pass on repairing the camera and just use the external charger. If that does not solve the problem, the camera will need to be repaired.
4/23/2014 12:38:43 AM • Nikon COOLPIX... • Answered on Apr 23, 2014
Nikon coolpix S6000 won't focus
To focus lightly press the shutter button (the one that takes pictures). Pushing it half way tells the camera to focus. When you're ready push it the rest of the way in and it should take a nice crisp photo. If not there's a problem. Take it to a repair shop, replace it, just rely on your smartphone, or learn to deal with blurry pictures. I'd personally go with the smartphone as you always need it anyway.
3/27/2014 6:11:39 PM • Nikon COOLPIX... • Answered on Mar 27, 2014
Battery exhausted won'y charge
Every rechargeable battery has a certain cycles of charging and discharging the battery. Not two batteries have the same life time. The amount of cycles a battery can have, can be influenced by the user. If you leave a battery without charging or discharging for months or even years, the lifetime can be shortened. That is why most of the time you get warranty on the equipment, but almost never on a battery. (sometimes a warranty of 90 days is given) Still when a battery won't charge, you could check all the parts in the chain. The AC / DC power convertor / charger the power cable. When the light on the charger comes on, you can assume the charger is working. With your camera you charge the battery in the camera. Looks almost the same. As soon as the green light comes on (starts to flash slow) you can assume the AC adopter is working. The charging of a fully discharged battery should take about 4 hours. If the green light goes not flash at all, check the adopter and check the USB cable. Be aware as long as the cable is in the camera, it can't be switched on. So before testing if the battery is charged, remove the USB cable. Last but not least, if you have a multimeter, you could try to measure the voltage of the battery. It should be a little above the 3.7 volt that is printed on the battery. If not you can be sure the battery is no good at all.
2/12/2014 2:52:42 PM • Nikon COOLPIX... • Answered on Feb 12, 2014
0answers
Battery exhausted won't charge
even new batteries can die. I only can advice you to try to start a charge cycle a few times in a row, but if the charger does not indicate it is charging, I'm afraid you really have to buy a new battery. I have a Nikon battery that is almost 3 years off age and in the camera it says capacity 100% NEW. But it is used on a regular base and charged regular.
1/24/2014 10:03:27 PM • Nikon COOLPIX... • Answered on Jan 24, 2014
LENS DON'T OPEN
Lucinda, Are you sure the battery is charged and ok? Is there anything you can see or hear when you switch on (try to switch on) the camera?
12/2/2013 10:07:22 PM • Nikon COOLPIX... • Answered on Dec 02, 2013
I am going to be traveling to southeast Asia. Am I
Get yourself a portable Travel Adapter and Power Convertor. The best one we have found in made by BESTEK 200W Travel Adapter & Power Converter, Model # MRJ201GU. Got mine on Ebay for less than $20.
11/10/2013 9:33:40 AM • Nikon COOLPIX... • Answered on Nov 10, 2013
How do you delete protected pictures
Unprotect them first. See page 89 of the manual: http://www.nikonusa.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/S6000_EN.pdf
7/7/2013 1:32:32 AM • Nikon COOLPIX... • Answered on Jul 07, 2013
"Memory Card is write protected" so I can't take pictures.
remove memory card ... left or right side of memory you will see one little button slide the button down or up... this button is protected your memory..
5/28/2013 10:41:12 AM • Nikon COOLPIX... • Answered on May 28, 2013
0answers
Nikon s6000
Be the first to answer 5/8/2013 10:44:03 PM • Nikon COOLPIX... • Posted on May 08, 2013Be the first to answer
The green light will show
Hi, I'd suggest trying a new battery, it sounds like your current battery isn't holding a charge so a new battery would fix that.
3/14/2013 5:51:26 PM • Nikon COOLPIX... • Answered on Mar 14, 2013
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
7/25/2012 9:34:36 PM • Nikon COOLPIX... • Answered on Jul 25, 2012
Lost software
You don't need any additional software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery, Picasa, or Nikon Transfer.You can download any of the other free Nikon programs at the second link above.
6/24/2012 9:38:59 PM • Nikon COOLPIX... • Answered on Jun 24, 2012
2answers
When I last took a
The lens of your camera is damaged and needs to be replaced to fix the camera.
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
5/24/2012 9:27:28 AM • Nikon COOLPIX... • Answered on May 24, 2012
Nikon COOLPIX S6000 Digital Camera Logo
106 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
lens won 39 t close off button
  • Cameras
