20 Most Recent
Vivitek H1080FD DLP Projector Questions & Answers
Vivitek D326MX DLP, does no power up right away.
Almost certainly a faulty switch mode power supply. Since these are both complicated and dangerous for the inexperienced to play with, the best advice will be to take it to a service centre for repair. It's almost certain to be either failing electrolytic capacitors, or a high value startup resistor, or both, in the smps :o)
DMD error code
the DMD is good ,
the Projector will still start up,even if the DMD is defective.
the lamp ballast or the mother board is defective
Projector image has a pink
Usually colour problems like this are due to one of two things:1. poor connection at either end of the cable, or2. a damaged connecting cable between projector and computer.Check these first before getting the projector to a technician.
How can a hook up
I recommend you connect the audio portion directly from the source like the DVD or Blu Ray disc player. Projectors are only designed for projecting a video to a screen and most of them does not have an audio connection. Which means no power amplifier to drive the speakers. Speakers has to be connected to a receiver or a power amplifier.
Speakers that have red and white inputs but have no external amplifier must have internal amplifiers. This means that the speakers need a power cord so that they are operate. Find the power cord and your problem is solved.
Hope this will help you out.
