20 Most Recent
Cisco SPA504G IP Phone Questions & Answers
Cisco SPA504G Firmware update issue
You need to make sure that your laptop and IP phone are on the same network subnet. For instance, if you IP phone's IP address is 192.168.2.24 than your laptop must be on the same network addressing scheme, such as 192.168.2.23.<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
We cannot get the 504g
change the configuration in your IP Phone change the setting to allow broadcast caller ID .
No dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
