20 Most Recent Kodak Easyshare M381 Digital Camera Questions & Answers
Trying to transfer pictures to computer. With
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
8/16/2011 6:09:47 PM • Kodak Easyshare... • Answered on Aug 16, 2011
One of my staff members
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
4/15/2011 8:25:26 PM • Kodak Easyshare... • Answered on Apr 15, 2011
Kodak easyshare m381 trouble transfering pictures
Consider NOT using the USB connection.
4/10/2011 3:08:56 AM • Kodak Easyshare... • Answered on Apr 10, 2011
Lauriewheeler@hotmaThe correct date appears on
That's up to whatever program you're using to print the photos. Depending on the program (and printer), you can have the date on the image, in the margins, or even on the back. Please refer to the documentation for whatever program you're using. If you still have problems printing the date, please refer to this post specifying the program you're using.
3/10/2011 11:24:03 PM • Kodak Easyshare... • Answered on Mar 10, 2011
2answers
Hello. I am unable to
Ok, Transfer the video to the computer and see if you have audio. If you still do not have audio, install this codec pack and try again
http://www.free-codecs.com/download/k_lite_mega_codec_pack.htm
It will help us rule out the possibility of the camera's speakers being faulty.
3/4/2011 1:39:27 PM • Kodak Easyshare... • Answered on Mar 04, 2011
How do i transfer photos
Install your driver in computer and connect your camera to computer. Open the new driver and flollow and choose the menu there.
12/20/2010 4:20:13 PM • Kodak Easyshare... • Answered on Dec 20, 2010
2answers
Battery will not charge and camera draws battery
Get recharible batteries.
7/25/2010 1:24:05 AM • Kodak Easyshare... • Answered on Jul 25, 2010
My camera wont charge
The usb may not be good
7/25/2010 1:20:06 AM • Kodak Easyshare... • Answered on Jul 25, 2010
Kodak M381 easy share camera the lens is stuck and
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
7/12/2010 3:31:43 PM • Kodak Easyshare... • Answered on Jul 12, 2010
I dropped the camera and batteries come off and
well ... either get it to the authorized repair center or get a new cam. drop damage is always heavy on the cam and this needs to be inspected by a qualified technician. but beware - repair might a bit less than the new camera would...
6/15/2010 1:12:55 PM • Kodak Easyshare... • Answered on Jun 15, 2010
I have an Easy Share m381 camera and when trying
Your camera won't write to the memory card until you get rid of the pics in the internal memory. Download any you want to save. Then, with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. You should be ok after that. Promise yourself you will never use the internal memory again.
5/30/2010 4:37:49 AM • Kodak Easyshare... • Answered on May 30, 2010
I droped my camra and it wont stay on and the
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
5/28/2010 4:35:48 AM • Kodak Easyshare... • Answered on May 28, 2010
tip
Kodak EasyShare M381 digital camera Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Kodak's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
Grainy pictures and not sharp
These cameras were designed to be high sensitive to light. If the Flash is set for Auto Flash, the camera tends to use ISO 400 whether the flash is fired or not. This was done to increase the working range of the flash.
In order to change this setting please go into the Menu (Capture+ tab) and set the ISO for 64, 100 or 200 in order to reduce the graininess. However this will lead to slower shutter speeds in low light.
2/21/2010 12:10:30 AM • Kodak Easyshare... • Answered on Feb 21, 2010
Kodak Digital Camera not being recognised when plugged in.
Do what the pros do...use a card reader.
2/18/2010 11:37:54 PM • Kodak Easyshare... • Answered on Feb 18, 2010
Can m381 be used as webcam ?
No. The camera is designed to store images to a memory card, not to stream them to a computer.
1/22/2010 11:24:17 PM • Kodak Easyshare... • Answered on Jan 22, 2010
Can't view pics on digital frame using new camera
You need to make sure that the pics are on standard jpeg compression, if not try opening file from your pc using mspaint then save file as jpeg
1/8/2010 4:42:25 PM • Kodak Easyshare... • Answered on Jan 08, 2010
I am looking for the Tutorial for using the Kodak
Hello
I suppose that the user manual will best explain all the function and directions for use. At the link below you will be able to download an updated soft copy of the manual.
http://www.retrevo.com/support/Kodak-M381-Digital-Cameras-manual/id/23553dj798/t/2/
Hope this can be of help.
Kind regards
Andrea
12/27/2009 11:23:13 PM • Kodak Easyshare... • Answered on Dec 27, 2009
3answers
.MOV from Kodak M893 IS camera are not recognized by Quicktime
The codec on mac does not recognise your file....try using a different player....vlc....gom player...mx player...instead of the one iTunes insist on chaining everyone to.
4/24/2022 3:27:18 AM • Kodak EasyShare... • Answered on Apr 24, 2022
Manual for easyshare camera c1450
You may download the user guide at http://www.fixya.com/support/r13011856-lens_error and the extended user guide at http://www.fixya.com/support/r13011856-lens_error
8/1/2018 7:25:03 PM • Kodak EasyShare... • Answered on Aug 01, 2018
Kodak Easyshare M381 Digital Camera Logo
23 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
one staff members
  • Cameras
