20 Most Recent Dream Maker Spas Dream Maker Spa - Eclipse Mocha with Cover Questions & Answers
Leaking from air control
Hi, i think i understand what you are explaining normally most fittings for the air system will be glued so there is a good chance that something has broken. If you would like to send me a picture of what part has blown off and i will be able to give you the solution and parts required. Please visit our website contact page as my email address is there, www.hottubpartsuperstore.co.uk Kind regards Mick.
4/19/2013 6:42:31 PM • Dream Maker Spas... • Answered on Apr 19, 2013
Dream Maker Spa lights BLINKING
Did you find a solution to this? Mine is doing the same thing.
11/20/2021 9:15:50 PM • Dream Maker Spas... • Answered on Nov 20, 2021
0answers
0answers
0answers
I have a Deammaker hot tub. The tub works and pump is running. When I turn on the air valve the is no change in jets. The air vave is opening when turned.
I don't know this model but most hot tub have a micro switch on the valve that starts the compressor to confirm turn the power off then removing the access panel and take the wires of the switch and connect to gether then turn back on if the compressor is working then the switch needs replacing if it is not workin the the compressor is faulty
1/18/2015 9:00:55 PM • Dream Maker Spas... • Answered on Jan 18, 2015
Spa wont turn on,there was a lightening strike.could that have ruined the spa
check the GFIC trip it and reset it, next see if any lights come on in the spa. if no you might want to check for voltage at the spa, if you have the set voltage 115 OR 230v . I would check fuses on the control panel . Hope this gets ya running again. ask if you need morwe help, and don't forget to vote if i was of help
11/25/2014 8:43:29 PM • Dream Maker Spas... • Answered on Nov 25, 2014
Plug hot tub in works then shuts off
Make, model, year?
5/4/2014 3:56:55 PM • Dream Maker Spas... • Answered on May 04, 2014
Model 8003- x - 400 when plugged in motor hums for about 10 seconds then breaker trips(no pump but display lights up
Sounds like the motor is seized. Of it cant turn over it will trip the breaker. Sometimes you can get to the shaft of the motor on the back end by removing a cover or cap. With a large flat screw driver or open end wrench you can sometimes spin it manually to break it free. If it is really stuck the pump may have to be dis-assembled or replaced.
4/13/2014 2:09:20 AM • Dream Maker Spas... • Answered on Apr 13, 2014
0answers
Air control valve leaking water
dis assemble the air control. check the gaskets for any damage or cracks
3/17/2014 7:21:56 PM • Dream Maker Spas... • Answered on Mar 17, 2014
Dream Maker Spas Dream Maker Spa - Eclipse Mocha with Cover Logo
1 questions posted
Top Dream Maker Spas Pool & Spa Experts
john h
Mike Cairns
Mike Cairns
Larry Ng
Larry Ng
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Dream Maker Spas Pool & Spa
Most Popular Question
leaking from air control
  • Pool & Spa
