20 Most Recent
Sanyo Xacti VPC-CA 9 Flash Media Camcorder Questions & Answers
Do u have an english
You can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/extranet/servicers/VPC-CA9_OM_English.pdf
Hi I have a new
I have the sam camcorder. It has the same problem. When you press the on/off button, it does not do any thing just red light blinking on the top. After wandering with buttons without really knowing what I am doing, I took it to Sanyo service center. They found the ribon connecting the LCD to main body being damaged. They replaced it and charged me $75 for that. After that the camcorder works good. I saw the ribon is very vulnerable. If you twist the camcorder just a little hard, that ribon may get shocked.
Problem with memory card
What model Sanyo camera? What type and size memory card? Just what problem are you encountering? Is there an error message?
Hi i have a sanyo hi 8 camcorder 25 plus years old and it loads and ejects and tape flashes continually whats the oroblem
It sounds like your Sanyo camcorder may be experiencing a problem with the loading or ejecting mechanism. This could be caused by a number of issues, including a damaged or broken cassette mechanism, a malfunctioning loading or ejecting motor, or a problem with the camcorder's control board.
To troubleshoot the issue, you could try the following:
- Make sure the camcorder is clean and free of any debris or obstruction.
- Check the cassette for damage, such as broken or bent spindles, and make sure it is properly seated in the camcorder.
- Try using a different cassette to see if the problem persists.
- If the problem persists, you may need to have the camcorder repaired by a professional.
Keep in mind that due to the age of your camcorder, it may be more cost-effective to purchase a new one rather than repair the old one. However, if the camcorder has sentimental value or is no longer in production, repair may be the best option.
Sanyo VM-D66P error: CASSETTE
There is a pulley that breaks inside but as these have been obsolete for over 20 years, I doubt it is repairable any more.
Fully working VM-D66p for £30 on amazon or fleabay.
