20 Most Recent
Samsung Alias 2 SCH-U750 Cell Phone Questions & Answers
SIM card
I think they are same or similar. I think if it fits it will work. Might be differences in the recovery speed between photos. To access card on computer you will need an adapter.
I dont know my unlock code for my phone or my phone number
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Phone was smashed with a
HI.If the pics was stored in the phones built in memory then we can't retrieved those picture .however if it was saved using the phones memory card then there will be a possibility that it will be retrieved.just find the memory card or the chip if you can still locate tht and you need a card reader to retrived those pictures.Insert the memory card to the memory card reader then connect it to your laptop or computer and try to access the device added on your laptop or computer then .Go to my. COMPUTER --access the device added there you can view those pictures on your chip.Now on your second problem.This screen and querty keypad is usually connected using a bolt on it.It can't be seen because it is covered by a plastic or there is a covering on it and inside on it there is a bolt on both sides.Now if the circular shape plastic has been loosen and cracked and the lining of the screw is also damaged then it would not be possible to repair because movement of the bolt will be by flipping up top to bottom and if it will be repaired it will eventually loosed up.Hope this idea helps.Thank you for choosing FIXYA.
