20 Most Recent
Samsung SGH-B130 Cell Phone Questions & Answers
Hello, I have a Samsung
you have to check your phone mike I think your mike is not working so that's why you are facing that type of problem
Hard reset b130
Enter *2767*3855#
All data will be lost, save all info to SIM or PC before total reset
Insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Reset code
Kindly, create a data back up and enter the code *2767*3855# and your password will be reset to 00000000
Samsungsgh-b130 reset code
Hello, please create back up data and enter this code on your phone. It will erase all data and reset your security code to default 00000000
