Hi
I
believe that everything else is fine rather it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine then it
can be due to the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
Testing a dryer's thermal fuse is much like testing its thermostats. Follow these steps to replace your dryer's thermal fuse.
The wires leading to the thermal fuse are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
There
The
going bad...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
20 questions posted
1,329 Questions
1,410 Questions
750 Questions
524 Questions
182 Questions
