20 Most Recent
Pioneer BDP-120 Blu-Ray Player Questions & Answers
I tried to play the
so long as its not a burned disc, in which the copyrights may have not transfered, it should work. However, try another blu-raydisc in player, if that works, its is the format of the disc. ask someone you know if they have the casino royale blu-ray and try their copy. try to isolate the issue as to the disc or player, if its the player, then contact the mfg. tech support.
Cant play bluray movies on
Hello cars2u,
Your computer may not have a blu-ray disk drive. You need to install one in order to watch blu-ray movies on your computer. Hope this helps, good luck.
- Joe
Unlock code for pioneer bdp140
Switch on the player & Remove any disc Close the tray Press Home Menu on the Pioneer Remote Select Initial Settings "Press the hack button on the remote" <-- The IR signal hack that's for normal DVD players with Philips pronto etc Select Options using the Pioneer Remote Select Load Default Once defaults are loaded complete the Settings Wizard Switch Player Off then On again Press Home Menu on the Pioneer remote Select Initial Settings Type 8520 on the Pioneer remote Region setting should now be 0
Will Not Recognize Disc
You need to install Blu-Ray Player software and that is most probabily a firmware which will help to recognize the DISC
Hi i bought a pioneer
Yes, that used to be possible - not anymore: the new ones have a different firmware that can no longer be hacked.
The only way to make it region free is to install a decoding chip on top of the original one - the way in which the free ones offered for sale online are done.
You can get more informations from the chips manufacturer's
http://www.multiregionupgrades.com/bluray/pioneer.htm
Stop playing my newer blue
I'm sorry for the difficulties you're experiencing in playing the new blu-ray discs. I understand that the player is updated with latest available firmware update. Hence it should playback the new discs. However, few new discs may require a future update to playback new discs as the Blu-ray technology is
developing everyday and adding more and more features to the existing
technology. It may take a few days to release the new firmware update based on the compatibility issues. However, I suggest that you try playing the same discs on a different player to confirm it is not an issue with the particular disc. You may also get a replacement for the disc from the place of purchase as a possible troubleshooting step.
Please try the above steps and let me know the result.
Thanks for understanding.
Trying to update firmware on
The reason it does this is because you are using a Mac's default un-zipping tool.
Download Stuffit Expander and it will work no problem. - www.stuffit.com -
It took me weeks to work this out. P O S.
