Video Download Studio is a tool which gives you the ability to download videos from streaming video sites. You can download videos from Youtube, Google Videos, ...
if its fitted with a screw down crown you need unscrew it anti clock, then pull crown out to first position and turn in either direction it should change one of the functions then pull it out to the second position and turn crown to set the other functionr remember to push crown back and screw back to case side its spring loaded on some model of AQ some models you need to pull crown in and out to change date then spin hands with crown to change day. IWC have a good website.
Can you tell me if you have a Da Vinci, Portuguese, etc.
I have a video for you that shows how to do it on a Da vinci model.
Hopefully it works the same.
Thanks!
ZERO-SETTING OF THE SECONDS-HAND & SUB-SECOND HAND ON THE SECTOR ADV1000 CHRONOGRAPH.
NOTE: The pusher buttons A, B & C are positioned on the watch at the 2 o'clock (A), 10 o'clock (B) & 8 o'clock positions (C), while the crown is at the 4 o'clock position.
1) Set the crown at the normal (in) position.
2) Push the B button twice.
3) Pull out the crown to the 2nd position (fully out).
a.) Seconds-hand setting: a push of button A moves the 2nd hand by 1 second. Move it until it is at the zero position.
b.) 2/100ths second hand: a push of button B moves the 2/100ths second hand by one 2/100ths second. A continuous push moves it quickly. Move it until it is at the zero position.
4) Push the crown back in to normal position.
QUICK-SET OF THE CALENDAR DATE
With the alarm switch off, pull out the crown halfway to the first "out" position (not fully out). Turn the crown clockwise to quick-set the date.
No manual, just this. You can however just search by the number of buttons, 2 , 4 or 4. They are all the same.
Google
4 button chronograph watch manual
