20 Most Recent
Sanyo PLV-Z700 LCD Projector Questions & Answers
I have an PLVZ700 that is showing a faint yellow
The Blue LCD has burnt due to either an old lamp or poor ventilation/blocked filters.
There is no cure for this except a replacement blue LCD panel is required. It is a specialized job and cannot be attempted by some one without the tools and experience.
Cleaning the filters may stop anymore deteriation.
I have a sanyo plv-z700
It's actually called the polarized glass filter for the blue channel and if you examine it, it probably had a brown burnt spot in the middle of it. You will have to take the cover off to get to it. It is usually held in place with a hex screw. It is very thin and delicate, so handle carefully, you may have to use tweezers or needle nose pliers to carefully lift it out. See
www.pacparts.com for parts and prices or search ebay for another projector that you can use for parts. If you are lucky, there may be a parts list and schematic of your projector on the site, so that you can see exactly what you need. But be forewarned, I priced one of these for my Sanyo projector and they are $93.00. You may have to disconnect the ribbon cable to get to it as well. Be careful with the cable as well because it is very thin and delicate as well and if you tear it, that connects to the Optical filter and that part is about $92.00. Not to scare you, just be careful and good luck.
MY SANYO plv-z700 HAS A
It might mean the temperature sensor is detecting that the interior temperature or lamp temperature is too hot and asking you to clean the filter or filters. The internal fan will blow air out one side and pull fresh air in on the other side. Check the side with the air going in and see if there is a foam filter. It should easy to remove. I clean mine in the sink and dry with a paper towel.
How can i download divers for sanyo xu 101 projector
To download drivers for the Sanyo XU 101 projector, you will need to visit the Sanyo support website. Here are the steps:
- Go to the Sanyo support website by typing "Sanyo support" into your search engine and clicking on the first link.
- Once on the Sanyo support website, click on the "Projectors" category.
- Select your projector model, which in this case is the XU 101.
- Click on the "Downloads" tab, where you can find the available drivers and software for your projector.
- Look for the driver that you need and click on the download link.
- Follow the instructions to download and install the driver.
If you have any issues with the download or installation process, you can contact Sanyo customer support for further assistance.
My Sanyo dp42481 pic is upside down and mirrored how do I fix it
If your Sanyo DP42481 picture is upside down and mirrored, you can try adjusting the settings on the TV. You can do this by going to the Picture Settings menu and selecting the "Picture Orientation" option. From there, you can select the "Normal" option to reset the picture orientation. If the problem persists, you may need to contact the manufacturer for assistance.
Sanyo AWD-AQ4000(S) U3 error code
The "U3" error code on a Sanyo AWD-AQ4000(S) air conditioner indicates that there is a problem with the unit's compressor. This could be caused by a variety of issues, such as a faulty compressor, a malfunctioning control board, or a refrigerant leak.
To solve this issue, I recommend the following steps:
- Make sure that the air conditioner is properly plugged in and receiving power.
- Check for any visible damage to the unit, such as bent fins or loose wires.
- Check the air filter and clean or replace it if it is dirty.
- Check the outdoor unit for any visible damage or debris that may be blocking the airflow.
- Check the refrigerant levels and make sure they are at the proper level.
If those does not work, it may be time to check with a professional!
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
