20 Most Recent
Veo Stingray Questions & Answers
Need driver for veo stingray 330V that works with Windows Vista
download the driver for veo at:
http://www.softsci.com/veodrivers.htm
when download is complete, click (open folder)
select the file (veo_330V_v002.exe) right click it
select properties
select compatabilty
put a check in box (run this program in compatabilty mode for)
choose (Windows xp (service pack2)
then apply
the double left click the file
and Bingo Vista will install it
I am using mine on yahoo messenger as I type now!
Have Fun
Hope this helped!
1/4/2017 9:24:20 PM •
Veo Stingray
Answered
on Jan 04, 2017
Run a veo webcam on windows vista
Hi.
Unfortunately, it appears that there are no Vista drivers available for this product.
You will not be able to use your web camera on Windows Vista systems.
Perhaps manufacturer will release such drivers, but it cannot be guaranteed.
I strongly recommend buying hardware from bigger manufacturers, as it is almost sure that the drivers for new operating systems will be released.
I am truly sorry that your problem cannot be solved.
Your responses are intended to improve the level of service provided. Please rate your experience.
9/14/2016 2:23:33 AM •
Veo Stingray
Answered
on Sep 14, 2016
Driver teac webcam driver zl200530063216.4 i want
1st You download Webcam Driver.
Driver teac webcam driver zl200530063216.4 i wantAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
8/18/2014 11:36:19 AM •
Veo Stingray
Answered
on Aug 18, 2014
Webcam resolution/color problem
Unless the camera itself is faulty, the only other thing to do is to uninstall the camera driver in add/remove programmes and re install the software again and give it a try and if possible put the camera in a different usb port.
3/5/2014 2:43:42 PM •
Veo Stingray
Answered
on Mar 05, 2014
My computer won't find the new hardware
this sometimes happens when there is insufficient power going to the usb ports top power a lot of hardware.
Try disconnecting any other usb connected peripherals and connect your cam in one of those other usb ports as the port may also be stuck in a loop unable to identify your cam.
restart your pc with the cam pluged in the different port if it is not automatically detected and it then should install.
3/5/2014 2:42:52 PM •
Veo Stingray
Answered
on Mar 05, 2014
HELP!!!!!!
just search webcam driver for xp in website of manufacture (Veo Stringray) of webcam
, download it by providing its model no and install it and finally restart your system.
3/3/2014 3:13:41 PM •
Veo Stingray
Answered
on Mar 03, 2014
Cann't find my disk to in stall my veo stingray cam
The first step of this solution has a website that you can download the exact driver that you will need and if your running vista your problems are now fixed.
This fix will work for all of the VEO Stingray problems because it
gives a good driver download site and it tells you step by step how to
get your cam to work with VISTA Good Luck and let me know if this fixed
your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam.
This works with all of your programs that vista will not run.
3/3/2014 2:56:18 PM •
Veo Stingray
Answered
on Mar 03, 2014
Veo Stingray - with no disk
your problems.
3/3/2014 2:56:03 PM •
Veo Stingray
Answered
on Mar 03, 2014
Veo Stingray #330VB39C
If you are running vista this solution will help
your problems.
3/3/2014 2:55:51 PM •
Veo Stingray
Answered
on Mar 03, 2014
Software
In the first step of this solution there is a website that you can download the drivers you need for your VEO
your problems.
3/3/2014 2:55:35 PM •
Veo Stingray
Answered
on Mar 03, 2014
I can't find my disc
Go to the website in the first step of this solution and get the driver that you need and yes you can still install and run your veo. there you go no more hunting
your problems.
3/3/2014 2:55:15 PM •
Veo Stingray
Answered
on Mar 03, 2014
Web cam connection
your problems.
3/3/2014 2:55:04 PM •
Veo Stingray
Answered
on Mar 03, 2014
