20 Most Recent
Lasko 2506 16", 3 Speed, Oscillating Fan Questions & Answers
Won't turn on
Check thermal fuse in-line in the white wire going to the motor windings. 2A/115 degrees C.
The switch of my fan is broken. It needs
You have a problem indeed. If it were MY fan, I would unplug it first, then I would remove the switch and solder the loose ends of the wires together that I removed from the switch.
I would also carefully wind black electrical insulating tape around the connection so nobody would get a shock from it or short out to ground. Then I could use the fan, but will have to plug and unplug it from the power source. If you have power points just flip the wall switch.
Jim Hart
Blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
Disassembling a cyclone by lasko for cleaning
There are screws hidden between the slats on the side of the fan that are not obvious. You will also need to pry the fan apart as it snaps together. On the back by the power cord is a round tab over it. There are some screws under it. They hold the motor to the back assembly. It took about 7 minutes for us to get it apart today because of the screws being hidden on the sides. After a cleaning it won't turn on now.
5/27/2023 4:32:57 AM •
Lasko Dryers
Answered
on May 27, 2023
