20 Most Recent
Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio Questions & Answers
How to off tk 3107 CTCSS
Simply you read the program by KPG55D and go at ctcss and delete it by pressing the delete key and press enter after deleting.
Yaesu Ft-60R with Kenwood TK-3107
ok guys!! i have gold for your prob huhuh
go to this website and u can get anything about all model TK
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
How to reset tk 3107 keenwood
The Kenwood TK-3101 are programmed through the old DOS based program and a program cord. The only way to "reset" is also through the cord. Finding both the program and cord might be difficult but i do have those and let me know if you need assistance?
Where to find the ctcss function
tk3101 has nothing to think about. on/off channel select.
red light transmitting beep battery empty green is receiving
search for kpg tk3101 and kpg 22 from ebay to programm.
Only difficult is that xp or win 7 will refuse first times the commport
Tk-3107 but can't talk to my friends who already
there are to many options to solve, And to few information given by you
1 first turn on the sound knob (most likely)
2 read the channels of you're equipment and those of you're friends
software is all over or use an old radioscanner or freq counter.
3 put new software in all the equipmant. Easiest way
How to reset tk 3107 kenwood
It is a PC programmable radio.
You'd need the program and interface cord.
if you want I could reprogram for a small fee.
Let me know if you need help.
LED indicator stays green -
The squelch circuit is open. Adjust it and the noise will go away and the light will go off when no-one is talking.
Intermittent High pitch squeals
other than check your wiring for rubbed spots or loose connections, I don't know. maybe try swapping parts one at time with your buddy. maybe your headset?
Unable to program tk-3207
hi, all i can think of is- A, the computer is way too fast for the program you are trying to run, what you need is a really old slow computer or B,
check the COM port settings on your computer.
click start, right click on my computer, click properties, then click on the hardware tab, then device manager.
then there will be a 'Ports COM &LPT' just make sure the com port number is the same one as you are using on the software. Hope this helps.
