20 Most Recent Sanyo 12KHS71 Split System Air Conditioner Questions & Answers
2answers
How do i set unit for moisture removal
there would be a button nameng mode on your remote control press it untill it shows dry mode now it will remove moiture from the room as long as it works in dry mode.
6/3/2011 3:05:43 AM • Sanyo 12KHS71... • Answered on Jun 03, 2011
Sanyo sap-71a will not start using remote the
Simple, remove power and then unplug DC wire from indoor display for 2 minutes.Again plug it, power on. And also remove batteries and re insert in remote and then use. If still problem, your signal receiving sensor defective. You have to repair/replace indoor PCB.
2/5/2011 8:36:18 AM • Sanyo 12KHS71... • Answered on Feb 05, 2011
Removing humidity
Hi,this is a common feature of the split unit when the humidity is below 40%,so don't be bothered,your unit is in a perfect working condition.
Thanks and take care
5/28/2010 10:37:46 PM • Sanyo 12KHS71... • Answered on May 28, 2010
Where can i get manual of the part, reference #
Here is links for all the manuals for your unit.
http://www.sanyohvac.com/docs.php?id=12KHS71
The following are located at the above link:
  • 12KHS71 Dimensional Data
  • 12KHS71 Installation Manual
  • 12KHS71 Service Manual
  • 12KHS71 Submittal Data
  • 12KHS71 User Manual
8/22/2009 4:01:35 AM • Sanyo 12KHS71... • Answered on Aug 22, 2009
Sanyo 12KHS71 splt system AC wall unit fan seems froze up
MOTOR STUCK OR NO GOOD REPLACE
6/20/2009 2:24:43 AM • Sanyo 12KHS71... • Answered on Jun 20, 2009
How do I set the time on a sanyo KHS 1872 air conditioning remote? not the timer but the time the clock?
the remote does not care what time it is. The AC unit has all the unit control's and info on it. Just like a tv remote the tv has all the info on it.
11/11/2022 7:05:41 PM • Sanyo Heating &... • Answered on Nov 11, 2022
How can I disconnect the heat on a Sanyo heating air conditioning wall unit 12000 but.
no info generic answer check and test thermostat and wiring circuit fan & heat should not be coming on when in a/c mode
8/18/2022 11:52:16 AM • Sanyo Heating &... • Answered on Aug 18, 2022
Sanyo ptac model# STW1223C2P no heat
Contact Sanyo directly to request the information.
3/29/2022 11:44:37 PM • Sanyo Heating &... • Answered on Mar 29, 2022
Service manual for Sanyo STW1223C2p
You can purchase the service manual from this website:- http://adfoc.us/60685483181460
3/20/2022 12:08:35 PM • Sanyo Heating &... • Answered on Mar 20, 2022
My sanyo wall heating and air unit wont turn off with it turned off
possible bad switch
1/20/2022 3:21:42 AM • Sanyo Heating &... • Answered on Jan 20, 2022
Need Access codes for a Polar Universal A/C Remote
polar 9045702 c?digo do LG
1/5/2022 9:18:31 PM • Sanyo Heating &... • Answered on Jan 05, 2022
4answers
This unit just installed...but purchased
Check for the correct voltage intake the capacitor needs to be replaced as its a very old ones need to be replaced by new one.
9/8/2021 1:23:15 PM • Sanyo Heating &... • Answered on Sep 08, 2021
2answers
Have a Sanyo KS2472 split inverter unit. On turning it on, operation light blinks and does not cool. Also compressor does not seem like it turns on outside. Please help.
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
7/30/2021 1:43:53 PM • Sanyo Heating &... • Answered on Jul 30, 2021
Sanyo air conditioner remote no longer controls my air conditioner
Hi Eugene, try replacing the remote control batteries You can do a test to see if your remote control is broadcasting Take your cell phone, put it in camera position and point the emitting LED of the remote control towards the camera, press any of the keys and see if you notice that a light emits, if so, the remote control is fine, if not, replace the remote control I hope you can solve the problem Regards Franco Dosil Hola Eugene, prueba reemplazar las pilas del control remoto Puedes hacer una prueba para saber si tu control remoto esta emitiendo Toma tu celular, ponlo en posicion de camara y apunta el Led emisor del control remoto hacia la camara, presiona cualquiera de las teclas y observa si notas que emite una luz, si es asi, el control remoto esta bien, si no, reemplaza el control remoto Espero puedas resolver el problema Saludos Franco Dosil
8/26/2019 3:51:54 PM • Sanyo Heating &... • Answered on Aug 26, 2019
Where can I get a filter for the sanyo khs0951 mini split a.c. unit?
https://lmgtfy.com/?q=khs0951+filter
8/25/2019 10:59:02 PM • Sanyo Heating &... • Answered on Aug 25, 2019
Sanyo new wick wont fit an yet they are tellimg me the model numb is right.
Could be the wrong part in the right box??? It does happen.
7/10/2019 12:44:27 PM • Sanyo Heating &... • Answered on Jul 10, 2019
Sanyo 12KHS71 Split System Air Conditioner Logo
Popular Tags
8 questions posted
Top Sanyo Heating & Cooling Experts
Jay Finke
Jay Finke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Heating & Cooling
Most Popular Question
sanyo sap 71a will not start using
  • Heating & Cooling
