20 Most Recent
Uniden EXI 7960 Cordless Phone (EXI7960) Questions & Answers
Handset Won't Connect to Base Station
Here's is the fix, I just had the same problem.
I have 2 handsets here and just had replaced in 1 of the handsets.
Here's the trick, make sure the correct handset is in the correct base. The way this is done is when one of the handsets are in their bases, they will show either HS1 or HS2 in the upper right hand part of the display.
When they are in the correct base, then go push the Find HS button on the main base and you will hear the page feature paging the other base.
When the 2nd handset starts beeping just push the Find HS button again and other handset should work.
After that it don't matter which handset is in which base.
Let me know if this works for you.
Thanks,
Brian
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
How to register a new handset?
Unfortunately, the EXI5560 is not an expandable cordless telephone system. The base can only use the handset to which it was originally linked at the factory.
Similarly, the DXA15588 handsets need to be paired to that base, not just to any Uniden cordless phone base. The first handset gets registered while it is charging in the main base. Charge the second handset fully in the charging base. Make sure not to use the phone for any incoming calls during the registration process. Take the first handset off the main base. You do not have to put this handset on the other charger and put second handset on the main base. Wait for the Charge/In Use LED to begin to flash. Wait at least another 5 seconds before removing the second handset from the main base. That's when you should be able to use the find HS button on the DXA15588-2 main base to get both handsets to beep.
I hope this helps. You can find the manuals for these phones at the following sites: https://www.uniden.info/download/ompdf/EXI5560om.pdf and https://www.uniden.info/download/ompdf/DXAI5588-2om.pdf .
