20 Most Recent
Nitro Collectable Fishing Boat Patch,emblem, Ww Questions & Answers
Wheres my bilge pump
It's located in the rear compartment centered on the bottom of the boat in front of the transom.
2/5/2015 3:37:35 AM •
Nitro...
Answered
on Feb 05, 2015
1997 Nitro bass boat 640 LX. Where can I get an owner's manual?
www.passagemaker.com/.../boat-
manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I need complete operating manual for 2001 Nitro 175 Sport Fish ski boat. Peter Swanson April 6, .... I am looking for a Manuel for my Italian made 1997 AquaViva Frontier 6 meter cruiser. Thank you,. Jeff ... Have purchased 1989 Pro Craft Stalker 180 Bass Boat.
Boat motor won't start. battery fully charged
I would have the battery tested anyway to make sure you don't have a dead cell. Usually even with a weak battery the starter will try to engage the flywheel on top of the motor.Besides the battery check the fuse located on the motor. If all is good then you can remove the starter for testing and possible rebuilding.
Bilge pump on 1996 nitro bass boat inop
Check to make sure the fuse is good and you have power going to the switch and then to the wires (brown for positive and black for negative) in the bilge area using a 12 volt tester. If you have power to the brown wire while grounded to the black wire then the pump will need to be cleaned, have the impeller replaced or replace the pump. The pump is located in the rear compartment attached to a board mounted to the inside bottom of the boat at the center near the transom.
