20 Most Recent
Black & Decker CHV9600 Handheld Vacuum Questions & Answers
Is not charging - no red light
Yes, it can be replaced. Can be ordered from Black & Decker. Some people would say it's worth fixing others would not. Don't know cost of battery -- probably under $20.
How do i open the B&D dustbuster chv9600 to
There are screws in the handle of it, the battery is also in the "Base" handle simply locate all the screws, and unclip the case halves with a flat blade, and the battery is inside.
Won't recharge. very weak.
If you know that the charger is actually working and supplying the correct voltage.Then the age of the unit would suggest that the battery is exhausted and it would be cheaper to replace the whole unit.
Hope this was a help.
I have a Flex hand
no the hose,, check the filter and compartment behind the filter.. Note if there is air passing through the filter,, or being sucked through it.. If not chances are the extractor fan inside the machine may have broken ou will need to open it up and replace the fan.. Its an easy task all u need a a philips screwdriver and a blade typre
B andD dustbuster makes loud grinding noise. how can I fix this problem? It is a Pivot lithium 20V unit
On 20V Black and Decker hand vac I was broken motor mounts. I took a housing off with 4 screws and could see that after 2-3 seconds of running the motor would move outwards and pull the fan into another housing. There are 6 struts that the motor rests within. But they do not provide enough friction to keep the motor from moving outward. So I cleaned everything off well, and wiped it down with some acetone. Then I epoxied these struts to the motor body. I think this will work.In the photo you can see a screw. There are breaks in the plastic body that the screw would secure.You can see some struts epoxied to the motor body.
I am charging it for the first time. How can I tell if the battery is charging?
Is it a 'Computer (laptop - Notebook - Chrome Book)', the Category you posted to, or a phone, or a car battery or a Drill Battery Pack, or......................
All questions must have make model (what it is)
_Most_ chargers have lights, Red flashing for charging, Green for full. _Most_ batteries take about 8 hours to fully charge. You can see _some_ charge in an hour.
Vague answers to a vague question. Click COMMENT under my post and fill in the blanks, and we will tell you the _CORRECT_ answer :>)
