20 Most Recent
Powermatic 1660804K 66 10" 5 HP 3 Phase 208/230V Table Saw w/ 50" Accu-Fence & Rout-R-Lift Questions & Answers
The crank to raise and lower the blade on my
The square tooth screw and nut tend to fill with sawdust, which saturates with oil to cause the threads to bind (like a dirty nut and bolt.).
Clean the bolt with a cleaner, then apply a little wax to the threads (crayon or bees wax). Be sure to run the assembly up and down to cover the whole "bolt" and make sure to apply to the point of the screw that assures some of the wax works into the nut.
Wax is less likely to cause wood dust "mud" that WD-40 or other lubricants would cause.
Check the slides or guides that guide the assembly as well. CLean and lubricate with wax as needed.
Let me know what you find out.
Powermatic manuals
L Luke, closest I could find is May 1983.
http://vintagemachinery.org/pubs/655/6140.pdf
How do I adjust the worm gear on my table saw?
I believe that that model of Powermatic has a lock for the blade angle that also extends and retracts the casters for moving the saw. You may have unlock or change the handle position to allow for blade angle adjustment. You can get a manual or information at the Powermatic website to show you how to change the settings on the saw. Hope that helps.
Need help wiring a 5HP 1Phase motor on Powermatic 66
As you only have 4 wires from the motor it should be straight forward as two would be from the start winding (Black and red) and the other the run winding (White with yellow stripe and Blue). You should be able to check this with a tester as there should only be continuity between the wires as mentioned above.
Reference the thermal switch, I am not 100% sure on the color codes but have attached a diagram which should help but will advise as best as I can on the connection. The diagram is for a high/low voltage but you can disregard the winding on 3 and 4 but should help on the understanding.
Join the blue and black wire from the motor together and connect to the black wire from the supply. You should be able to run the motor (Excluding the thermal switch) by connecting the White with yellow stripe and the red wire together along with the white from the supply. To include this switch I would presume that you would connect the red wire from the motor to the brown wire from the thermal switch, the yellow wire from thermal switch to the White with yellow stripe from the motor and finally the white wire from the thermal switch to the white from the supply.
