20 Most Recent Bose L1 Model II Dual Bass System with ToneMatch Questions & Answers
2answers
The Tone Match unit is not receiving power
If you are using the Bose ToneMatch cable (black cable - the connectors are round barrels with square connectors). Then this should work fine. If it doesn't then try a different cable. You can use a network Cat-5 cable. Note - if you are connecting to an L1® Model I or L1® classic then you need an T1 Power Supply. T1 ToneMatch Audio Engine power supply tone-match-unit-not-receiving-power-l4qeg2fyniuwsgnfiobf0ph3-1-0.png
1/17/2015 3:43:01 AM • Bose L1 Model II... • Answered on Jan 17, 2015
Bose 2020 radio isn't connecting to 2016 multi cd changer. CD light come on but radio doesn't recognize disc 2, 3, or 4.
If your Bose 2020 radio is not connecting to your 2016 multi-CD changer and is not recognizing discs 2, 3, or 4, there are a few things you can try to troubleshoot the issue: 1. Check the connections: Make sure that the multi-CD changer is properly connected to the Bose 2020 radio. Check the connections for any loose or disconnected cables. 2. Check the disc format: Make sure that the discs you are trying to play are in a format that is compatible with the CD changer. Some CD changers may not be able to read certain formats or may have trouble reading scratched or damaged discs. 3. Clean the discs: Try cleaning the discs to remove any dust, dirt, or fingerprints. Use a soft, lint-free cloth and wipe from the center of the disc to the outer edge. 4. Clean the CD changer: Dust and debris can build up inside the CD changer, causing it to have trouble reading discs. Try using a CD cleaning disc or a can of compressed air to remove any dust or debris that may be inside the CD changer. 5. Reset the system: Try resetting the Bose 2020 radio and the CD changer. Unplug the power cords from both devices, wait a few minutes, and then plug them back in. If none of these solutions work, there may be a problem with the CD changer or the radio. You may need to contact Bose customer support for further assistance or take the devices to a qualified technician for repair.
4/26/2023 4:55:41 AM • Bose Car Audio &... • Answered on Apr 26, 2023
2004 Chevy Silverado 1500 with Bose radio wire colors and what they do?
https://www.modifiedlife.com/2004-chevrolet-silverado-stereo-wire-diagram/
3/3/2023 1:14:51 AM • Bose Car Audio &... • Answered on Mar 03, 2023
Need color code wire diagram for a 2003 Nissan Pathfinder SE with Bose premium sound system please?
Get yourself a digital multimeter. Find the +12V constant, 12V remote, and ground. Connect them to the new head unit. For speaker wire get yourself a 9V toy battery and listen to poping noise. If you have a factory amp you need to power up the factory amp. Use the wiring diagram below to serve as a guide. Test your wire first before connecting them. NISSAN P o w e r Memory (+12v Constant) Red Ignition (+12v Switched) (varies) Brown or Green Ground (-) Black (varies - most don't have one) Illumination RED / White Dimmer RED / Black Power Antenna Green S p e a k e r s Right Front (+) Brown Right Front (-) BROWN / White Left Front (+) Black Left Front (-) BLACK/ White Right Rear (+) Blue Right Rear (-) Pink Left Rear (+) Red Left Rear (-) Green Found here https://www.google.com/search?q=2003+nissan+pathfinder+se+radio+wiring+diagram ..
1/6/2023 6:11:28 AM • Bose Car Audio &... • Answered on Jan 06, 2023
Have a Bose Hdd stereo
assuming that you are talking about internal hdd storage mp3 player all you have to do is see if the hard disk is removable and connect it to a laptop with the usb cable ...or if it have a usb cable connect it to a computer and the hard disk will appear in the my computer area (folder ) by the device name ..or like a removable storage device ..(it will be better if it came with a driver for it ...a disk that will manage it )
but in most cases this is not needed ...eiter you connect it with the usb cable to a computer ..and in the folder I just describe you will find the music you mentioned...and just click on it ..and delete ..After that just drag the folders or copy and paste the music in the removable storage device in the my computer folder...
another way is look in the menu and choose the folders than on options delete them ..after that add the music by importing from a usb flash drive (stick ) or any other storage supported..
But the most simple way is if the hdd is removable ..and to place it into a computer ,,and add the stuff and remove the other you do not need..
if you provide me the full name and serial I will look for a manual but from what you described all I found is this one ..and it has no manual...
http://www.techfresh.net/the-bose-new-car-stereo-system/
But from what they say ..it supports even transfer from an ipod or a usb stick ..so it may be conected to a coputer also ...by a usb cable ..
you can also copy the music from the disk by selecting the folders and copy to hdd..
7/26/2022 8:48:04 AM • Bose Car Audio &... • Answered on Jul 26, 2022
Anyone know how to get a manual for a bose PY15B car stereo in a 2009 nissan altima
contact the manufacturer (bose)of the sterio unit and see if there is a pdf version that can be down loaded
8/21/2015 7:42:19 AM • Bose Car Audio &... • Answered on Aug 21, 2015
I would ask if any one can give me code for my Eurovox
http://www.fixkick.com/power-elect/Keep-Alive/keep-alive.html old post but im back filling this so searchers can find it.
5/31/2014 2:59:56 PM • Bose Car Audio &... • Answered on May 31, 2014
What is my radio code for my Mercedes Benz clk 430
I need a code to add my cell phone in my radio for Mercedes Benz 2006 clk 350 please
3/17/2014 6:37:17 PM • Bose Car Audio &... • Answered on Mar 17, 2014
I have the boss bv9964b and everything works but
touch scren dosent work ho do u reset it
1/15/2014 2:35:29 PM • Bose Car Audio &... • Answered on Jan 15, 2014
0answers
Bose L1 Model II Dual Bass System with ToneMatch Logo
2 questions posted
Top Bose Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Alexander
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Car Audio & Video
Most Popular Question
tone match unit not receiving power
  • Car Audio & Video
