20 Most Recent
Omega Rear Drive Wheel Snapper Mowers Questions & Answers
How do you test the module on Briggs & Stratton motor
Check to see you have voltage getting to the module and you are getting spark.
If you are getting voltage to the module but no spark it means either the module is bad or the coil is open. You can check the coil windings with an ohm meter... no continuity means the winding are burnt. Dead short means the windings have fused to the core.
Next test is to try another module.
My briggs and stratton Model 12H802 engine is hard starting
hard starting on small four stroke engines is often related to valve clearances closing up due to normal wear. Its not a hard job if your a mechanically inclined. Few small tools, feeler gauge and new gasket for the valve cover. maybe a 30-40 min job .....many youtube videos.
Need to know how to adjust the rubber drive wheel
Usually just replacing the drive wheel will fix the problem. There are two allen head set screws on the disc mounted on the engine shaft visable through the hole in the rear of the mower. However, don't expect when you loosen them that the disc will move up or down freely. I've only ever move one by taking the engine off. I'd try replacing the rubber drive wheel first.
