20 Most Recent
Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer Questions & Answers
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
09-800 Invalid Toner Cartridge Message
Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Fuser module fails to warm up
Hi Anonymous,
I suspect your printer is quite new.
I think your Fuser unit to be at fault. You need to order a new spare fuser unit from Xerox or investigate further.
Good Luck.
How do I fix our Printer?
Tebogo,
This sounds like a power supply problem to me.
I would get in touch with Xerox concessionaires as soon as you can it could be a faulty power supply or one which needs upgrading perhaps. If it's not too old then I'm sure theres a fix.
Good luck.
Main unit cover open
Are you receiving an error message 01-100 Cover Open message? The interlock could be dislodged or the tab that actuates it could be broken off the front cover assembly. You need to examine those areas and if either of those are the cause, replacement of those parts should repair it.
22-511 error
On the right side of your paper tray, where the "Transperancy/Paper" selector is, if you look, there should be a plug covering one of the two holes above the switch. This error is typically caused by this plug breaking out.
Regards.
