Hello, Alex -
Fixya.com does not sell ANYTHING. It is a website intended for asking and answering questions on how to go about REPAIRING THINGS.
I would try to find a business which sells the air conditioner filters for your model of Artctic King air conditioner if I knew where (what country) you resided. Fixya receives questions from people worldwide. You can choose comment and type your country of residence in the Comment box.
I am answering from the USA.
Best wishes.
exhaust when you want to change air inside room more than you want cooling and dehumid efficiency. It ports air to outside, to be replaced by air from the outside (often from elsewhere in house, rather than via the AC unit). Does that answer it?
Question edited for clarity, full 'make model (what it is)'.
Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks!
Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
Repair Clinic has some good ideas, but your model is discontinued
Here are the steps you might want to follow:
Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping.
Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off.
If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
