20 Most Recent
IT Works 3045 Digital Camera Questions & Answers
It wont let me take
Sounds like the SD memory card is locked. There is a small switch on the side of the memory card, make sure it is set to "unlock".
No power
Please check your battery for wear down and power switch for defective.
Regards
I have cmaera marked
Download free driver manual on your product website for free.
Go to product website(i.e: canon.com,sony.com)
Go to support menu
And click the manual and driver downloads select your product and download the manual and driver for free
How do I take the lock off my camera so that I
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
I am trying to erase pictures from the memory card
Hi
Thank you for using Fixya!
Remove the memory card, check the sides for a switch or a slider. slide it or switch it on the opposite direction. Reinsert memory card and try deleting the photos again.
Hope this help
The driver is outdated and will not run on my new
You'll have to go to the IT works web site, follow links for support and downloads, entering the details of your operating system and camera model as you go. You should eventually come to a webpage which has the driver you need available for download.
Can i charge my camera from my usb port
It should charge but quite a bit slower. Figure about 4 to 6 hours for a full charge. Of course the computer has to be running to power the usb port.
You may also have to change settings for the USB under control panel system hardware device manager then select properties of the usb port. There will be an option for how much power the port will supply.
Or you can just plug it in and see if it works. Most newer ports (USB 2.0 type) support powering usb devices. Only a few older ones (usb 1.0's) won't or can't.
Tip about cameras with Memory Care Errors
It is vital that you match generations when using SD cards in a digital camera.
An older camera will not like a new generation high speed large capacity SD card.
I have a Lumix TZ5 for example that just will not work with a high capacity high speed SD card.
If I simply swap the SD cards and put in an older generation SD card, 1 or 2 or 4 gigabytes, then it works great.
