20 Most Recent
LucasArts Entertainment Company Star Wars Starfighter for Windows Questions & Answers
Downloaded Starwars StarFighter from Steam.
The
I would say you are running a very advanced system for this game as the spec is directx 8. And if you are using windows 7 it may not be compatable.
You could try running it in compatabillity mode for vista or XP, if you havent already done so!?
9/19/2011 2:27:54 PM •
LucasArts...
Answered
on Sep 19, 2011
I need the Serial Key
Welcome to FixYa!
1. Try to look at the back of the CD case. If the serial key is not there,
2. contact the store where you purchased it. They should be able to give you the serial key.
3. You can also contact Lucas Arts by phone at 1-410-568-3670.
Thank you for using FixYa!
Jas247
3/19/2011 5:40:27 AM •
LucasArts...
Answered
on Mar 19, 2011
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
