20 Most Recent
Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690 Questions & Answers
Flames are shooting out of the grill area by the front knobs
I have had this happen & it is because your tube is clogged with a spiders web, I can about guarentee it; this happened to me 2 years in a row. Simply turn off the propane & disconnect the tank.....take off the grill grate & flame hood ....remove the tube & look inside it & see if its clogged....clean & put it back & everything should be fine.
Cover needed for Elite Grill 17690 w/islands
I just got off the phone with Grand Hall USA and spoke with Tameka. When Sears asks them to make things like this, they send them a couple samples. At the time of this email, Grand Hall has 6 of these left in stock with (I would assume) no replacements on the horizon.
The number is 214-550-8031 and they run $74 plus shipping. I hope this helps you all out. It took me a week of searching, but we got it done........thanks.
Rollo T.
I have a Kenmore Elite
First, since it's a Sears house brand, I'd start online with Sears Parts Central. Depending on which parts you're looking for, you can also try Appliance Factory Parts
http://www.appliancefactoryparts.com/gasgrillparts/brands/kenmore/Keep in mind, Kenmore doesn't manufacture anything. It's just a house brand name for Sears appliances. Actually NexGrill manufactures the Kenmore Grill line. So contacting them 800.913.8999 is also a possible source for parts.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Kenmore LPG Grill Model 141.16313800
I
Relace your propane regulator, they do go bad form sitting around, had the same problem you have. you should be able to disconnect from the grill, turn on the regulator and smell the propane, if not it's bad.
Kenmore elite lpg grill #16690
The ignition module must be replaced.
Check the battery first and make sure it is fresh.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Flare up and smoke
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
The first two burners on
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
You problem could be or probably is with the regulator...not enough gas
pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
My kenmore elite grill has a ceramic cooking grid.
check thermo coupling., its purpose is to keep heat at flame area-helps keep flame lit,like a pilot light... clean it with a finger nail file LIGHTLY- or use sand paper LIGHTLY, just to clean surface..
Continously firing ignitors???
This spark module has a feed back from each of burner igniters and when it senses the flame - it stops sparking.
Most likely you switched around the wires from the front burner igniters and the spark does not receive the right input.
If you turn on both front burners at the same time - does it stop sparking?
If it does, just switch the wires around
If it doesnt stop sparking, then
Check the electrical connection to the stove for possible reversed polarity and proper grounding.
Check all burner igniters for any damages (cracked or broken ceramic insulation).
Check all burners for proper assembly. Check if the burner cap is in place on every burner.
Clean all burner igniters, using a rubbing alcohol.
To check the burner ignitor switch
A good place to start would be the burner ignitor switches.Each burner control has a switch with two wires going to it. (One at a time) You can remove one wire from each switch to see if the sparking stops.If so then you have a shorted burner ignitor switch. Make sure the metal tip of the wire doesn’t touch you or ground.
Another possibility is a spilled liquid or a cleaning stuff could get inside a switch, causing a short.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Grill does noty get hot
try opening the tank very slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Were do I find grill cover # 15808
Since it's a Kenmore grill and Kenmore is a house brand name of Sears. Have you tried calling your local Sears or K-Mart store? If you did and weren't successful, simply measure your grill (Height, Width & Depth) and armed with that information, visit any home improvement center or hardware store that sells grills and accessories and I'm sure you will find one that fits.
Hope this helped you and Happy Grilling!!
