20 Most Recent Samsung NE595R0ABBB 5.9 cu. ft. Large Capacity Electric Range - Black Questions & Answers
I Need help to convert the range from 110v to 220v.
Hello Euardo, I am glad you have added the extra info. I think you need to replace the clock (with the timer) for one of 110 v 50 Hz, but I am afraid it will be hard to find that. I would advise, take contact with Samsung. Kind regards, Dik
3/6/2018 7:56:04 PM • Samsung... • Answered on Mar 06, 2018
Samsung Range control panel won't turn on.
Check the voltage at the ac cord. Make sure you have 240 there. Sounds like your missing one leg there
3/24/2014 12:00:11 PM • Samsung... • Answered on Mar 24, 2014
Samsung Range Stove. What does E4 code mean on it please?
Question moved from Samsung Heating to Samsung Range. According to Samsung Code E4 doesn't exist. Try refining my search query by adding the Model number https://www.google.com/search?q=Samsung+Range+E4+code ..
12/9/2023 7:17:46 PM • Samsung Kitchen... • Answered on Dec 09, 2023
What is the reason for Samsung electric range FTQ387LWGX oven making buzzing noise and taking longer to come up to temp?
It could be a bad connection on the element connectors causing the buzz and reducing the power going to the element.
11/11/2023 5:44:06 PM • Samsung Kitchen... • Answered on Nov 11, 2023
I Have E5 error code on my Samsung gas stove.
Samsung gas stove code E5 nx58h5650w meaning
6/24/2023 3:14:49 PM • Samsung Kitchen... • Answered on Jun 24, 2023
2answers
Samsung range. SA6 error code on it?
It is SAB not SA6. You are in Jewish Sabbath Mode.
What is the meaning of the error codes displayed on your ...
Samsung https://www.samsung.com > ... > Home Appliance Dec 21, 2022 - These error codes appear when the range is in demo mode. The oven and cooktop will not heat (gas cooktops will still ignite). See your user ...
Samsung model #NX58H5600SS/AA error code SA6. ...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 31, 2019 - Samsung model #NX58H5600SS/AA error code SA6. Approximately 4 yrs old. About 3 yrs but now the range and none of - Answered by a verified ... 1 answer · Top answer: All you have to do is accept the answer. There should be stars in the top left or right corner ...
error code 5a6 or sab
Appliance Video https://www.appliancevideo.com > question > error-co... If the range is displaying "SAb", it is in Sabbath mode. The oven, as a safety feature, will automatically turn itself off after 12 hours. Sabbath mode ...
5/6/2023 12:27:15 PM • Samsung Kitchen... • Answered on May 06, 2023
2answers
My Samsung gas range stove top won't stop periodically beeping and there's no error codes
If your Samsung gas range stove top is periodically beeping and there are no error codes, it is likely that the burner is not properly connected. Make sure that the burner is securely connected to the stove top and that the power switch is in the "on" position. If the problem persists, you may need to replace the burner or contact the manufacturer for assistance.
1/29/2023 11:50:33 AM • Samsung Kitchen... • Answered on Jan 29, 2023
Flame on our new Samsung gas stove too high... simmer is still boiling everything
It is generally not possible to reduce the flow of gas to the burners on a stove top. The burners on a gas stove are designed to operate at a specific flow rate, and reducing the flow of gas to the burners could affect their performance. If you are concerned about the amount of gas being used by your stove top burners, there are a few things you can try:
  1. Make sure the burners are properly adjusted so that the flame is the correct size for the pan you are using.
  2. Use a pan with a flat bottom that is the same size as the burner. This will help ensure that the burner is being used efficiently.
  3. Turn the burner off as soon as the pan is hot enough. This will help conserve gas and reduce your energy usage.
If you are still concerned about the amount of gas being used by your stove top burners, you may want to consider switching to an electric stove or using a gas stove with a more efficient design.
1/6/2023 9:20:40 PM • Samsung Kitchen... • Answered on Jan 06, 2023
2answers
My Samsung range display is flickering. No error code on diagnostics
loose connection or failing they dont give error codes for them
9/28/2022 7:47:27 PM • Samsung Kitchen... • Answered on Sep 28, 2022
Anyone has the service manual for NX60A6111SS
https://manualsfile.com/product/p1zrlim5v1.html Service information is for Samsung Engineers only.
6/22/2022 6:30:02 AM • Samsung Kitchen... • Answered on Jun 22, 2022
4answers
Samsung oven not heating just stays at 150, all burners on top work fine anybody know the problem?
Odds are ignite, call Samsung and they can point you to a professional in your area to fix it.
4/17/2022 6:56:46 PM • Samsung Kitchen... • Answered on Apr 17, 2022
Troublesome new samsung range converted to LP propane
Check the gas pressure is correct. Check the appertures are the correct size for LP. If either of these are wrong, that is your issue.
2/16/2022 7:45:05 AM • Samsung Kitchen... • Answered on Feb 16, 2022
With new samsung electric range , do i keep oven door open or closed when using broil?
The door must be open to use the grill.
7/3/2021 4:19:31 PM • Samsung Kitchen... • Answered on Jul 03, 2021
2answers
I have a Samsung fridge.
Hi and welcome to FixYa, I am Kelly. The best temp is 0 deg F or -17 C Frozen foods keep best at this temperature. You can operate it up to 10 F to save energy. Anything higher than 10 F and the ice maker will stop working. A good rule of thumb for freezer temps is to watch the softness of ice-cream. If it is too soft it is too warm. The ice cream container should be firm and not squeezable / spongy.
Thanks for choosing FixYa,
Kelly
6/21/2020 9:04:43 PM • Samsung Kitchen... • Answered on Jun 21, 2020
Samsung gas oven 6 months old. Oven light flickering and clicking sound
Clicking or cracking While oven is in use: These sounds are the circuit relays switching. ... You can try to remove the moisture by heating the cooktop (or oven), or by unplugging the cooktop and letting it dry for a couple hours or overnight. https://www.samsung.com/us/support/troubleshooting/TSG01110180/
4/15/2020 2:50:05 PM • Samsung Kitchen... • Answered on Apr 15, 2020
3answers
I have a samsung stove model #nx58h5650ws the oven will not come i tried un plugging it for 3 min. i don't know how to bring up the failure codes
First off: SAFETY! You are working with 220 Volts AC that could cause damage to you and/or the range. Turn off the Circuit Breaker controlling the range (usually on the wall in your Garage or Basement wall. GET a Professional to fix it for you. OR got to Lowes and get a replacement Range.
4/14/2020 1:18:26 AM • Samsung Kitchen... • Answered on Apr 14, 2020
I have a samsung electric stove, model ftq353iwux. The front right burner stays on high even when it is set on low?
Most likely the switch is bad and has failed in the full on position. I would start by replacing the switch or you might just swap it with another working switch on the stove and see if it does the same thing or if it works properly.
1/24/2020 12:56:00 AM • Samsung Kitchen... • Answered on Jan 24, 2020
How can I fix my Samsung self cleaning rang when it's reding c_31
C-31 is caused by an overheated PCB. The solution is to call for service.
1/6/2020 2:08:52 AM • Samsung Kitchen... • Answered on Jan 06, 2020
My Samsung range touchpad only works with some numbers/functions. The oven does turn on if the number can be pressed. MODEL NX58F300SS
A new control panel will cost almost as much as a new range
11/26/2019 9:06:44 PM • Samsung Kitchen... • Answered on Nov 26, 2019
Samsung NE595R0ABBB 5.9 cu. ft. Large Capacity Electric Range - Black Logo
2 questions posted
Top Samsung Kitchen Ranges Experts
vince
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Kitchen Ranges
Most Popular Question
samsung range control panel turn
  • Kitchen Ranges
