If that would be your case that the phone is always asking you to format the MMC, your MMC could have been damaged or getting into being corrupted, please try using another MMC, and reformat it, then re-boot the phone, see if that works.
If that works(your other MMC) it simply means that your MMC is corrupted or faulty, have it replaced (buy a new one)
there can be two reasons for this 1. there is a problem with your phones card slot: for this u will have to check if any other card works with it or not! 2. the memory card might be dead or corrupted: for this put the card in a card reader and check it! it its the first problem show your phone in a mobile repair center or closest Nokia care. and if its the second problem replace the faulty memory card! reply and rate!!
Just go to massage setting n back up the massage to mamory card . n for permanent setting go to setting then mamory setting n then select mesej default mamory from phone to mamory card ...
it's possibly because when you uploaded your files to your memory card, they weren't the right file type.
plug your memory card back into your computer, open the folder, right click on a file and go to properties.
if it isn't an mp3 type file, it will not play on most phones.
also, make sure you format the card before you put music on it.
BE CAREFUL. formatting the memory card will erase all of your data.
if u want to format memory card first format it, then to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
