From: https://www.computing.net/answers/hardware/epson-styles-nx420-printer-wont-print-black/85723.html
...I figured it out for my printer today... just got new ink, had the same problem, saw these posts getting me nowhere, so I figured ok the ink cartridge is fine... so what else is between that and the paper. I decided to go out on a limb and get a paper towel and clean off the little plastic nubbin that's inside the printer (the part that sticks into the cartridge, sticking out from where you place the ink) and it printed completely perfectly after that.
SOURCE: Printer wont reset...red light keeps flashing....HELP PLEASE
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
SOURCE: I have an Epson Stylus Color 860 and 880 printers
It's possible the parking pad (otherwise known as the cleaning station) that the printheads normally rest on have become clogged or degraded and as a result the pump is no longer able to pump the ink out of the pads or indeed out of the printhead nozzles as it should normally.
I'd be slightly worried that the "cleaning head" hasn't in fact damaged the parking pad area and reduced the effectiveness of the seal around the whole thing.
Unfortunately it's very difficult to explain without pictures so I can't provide a full solution but hopefully that gives you a couple of new avenues to explore.
SOURCE: I have replaced the Epson ink cartridges for
I Have this problem too with the pink ink, ive replaced it and now it will not detect that there is even an ink cartridge in the printer at all...
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
