Hi, I recently was given a 26" Sansui television, model HDLCDVD26SA. I am having problems connecting my Playstation 2 to the Tv. I can get sound, however the picture is in black and white. I have a feeling I just have the cables in the wrong spots but do not know where to put them. Could you please help me with this.
I assume your using either a yellow/white/red or yellow/green/blue/white/red rca lead to plug in to your telly, make sure they are all going to the same input ie, input 1 or input 2 and the correct colours
JustAnswerhttps://www.justanswer.com > TV Problems
Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ...
1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
The 128-Bit Emotion Engine is the first chip of its kind. No other mass-market computer technology on the market comes close to its power. In the PlayStation2, this chip is used as the workhorse of the console. It processes all physics and math calculations.
The PlayStation2 has a 128-Bit Emotion Engine. The 128-Bit part of the title means that this chipset both processes information and sends it over a 128-Bit bus (A Bus is the pathway between chips on a circuit board. A wide bus carries more bits of information and is thus faster than a narrower bus).
You may think that your PC has a faster processor, but remember that the Emotion Engine has inherently faster 128-Bit processing and it is just a part of the overall PlayStation2 power.
A small note for the really detail oriented: The reason that the speed is 294.912 MHz, is that it must be a multiple of a required processor speed that supports the DVD ROM operations.
* Dimensions: 301mm (W) x 178mm (H) x 78mm (D), (12" x 7" x 3").
* Weight: 2.1 kg (4 lbs. 10 oz.).
* Media: PlayStation2 CD-ROM, DVD-ROM, and PlayStation CD-ROM, CD Audio
This means your PlayStation 2 will basically play all your old PlayStation games (but not make them look any better), all music CDs and all North American DVDs.
* Interfaces: Controller Port (2)
These are the same as the controller ports on the current PlayStation.
* Interfaces: Memory Card Slot (2)
These slots are very similar to the ones on the original PlayStation, except they support the new, faster transfer rate.
* Interfaces: AV Multi Cable Output (1)
This is where you plug the cord that goes to the back of your television.
* Interfaces: Optical Digital Output (1)
This port will let you send data directly to a digital receiver. This is perfect if you plan to plug your PlayStation into a DTS or Dolby receiver and get perfect sound.
If you don't use digital output, your data will be converted to an analog signal and then be converted back to digital at the receiver.
* Interfaces: USB Port (2)
USB enables you to connect any number of devices to your system with a high-speed data link.
* Interfaces: I.Link (IEEE1394) (1)
The IEEE139 port is known by two names: I.Link and for Mac owners, FireWire - there are some minor differences between the two. This high-data transfer port has the advantage of supplying (some) power to devices that are connected. You can expect that an enormous number of hardware devices will use this port including speakers, printers, and other like devices.
* Interfaces: Type III PCMCIA Card Slot.
This slot is a lot like a laptop's add-in slot. Here you will be able to plug in a modem and eventually the connection for Sony's planned broadband network and hard drive.
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
wel becouse the modem is older than the new ones and the conection would no longer be recieving upgrades,even if you conected the ps3 or your xbox you would not have a strong enough conection to be able to play online peacefully i recomend u get braodband wit 3-7 meg connection and then u should have no problem conecting either console to your router/modem
