Canon MultiPASS MP730 All-In-One InkJet Printer Logo
Sandra klappas Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mp730 says waste ink near full - Canon MultiPASS MP730 All-In-One InkJet Printer
mohideen bava
Level 2:
Scholar:
  • Expert 199 Answers
  • Posted on Aug 03, 2011
mohideen bava
Expert
Level 2:
Scholar:
Answers
199
Questions
Helped
66210
Points
477
To reset waste tank full error in MP730.
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press "Set" and the display shows:
Test Mode [1] - [8]
CF-FH3 :WLD-11-02
4b. Press "8" and the display changes to:
Test Mode [1] - [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 - 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button - for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
  • cumulous Sep 15, 2011
    Performed the above instructions but the message remains.
  • Anonymous Oct 05, 2012
    IT WORKED!! Thank you, Mohideen. Completed all steps, it fed the blank paper thru but the ALARM light was still flashing at the end. I pressed the RESUME button & printer worked.
1helpful
Waste ink near full
There is a collection area in the printer that when the print head are not in use they rest over. It usually has a sponge\foam material. It collects excess ink and keeps the print heads clean. Any way, waste ink near full means it needs to be changed.
How to clean waste tank on MP730 "waste ink tank
  1. press menu - copy - #
  2. Select TEST MODE.
  3. Select [8] PRINTER TEST in TEST MODE.
  4. Select 3. [EEPROM CLEAR].
  5. select 0. [INK COUNT].
  6. press the [OK] key
  7. press stop to cancell
  8. restart the printer
1helpful
Waste Ink Near Full on Canon MP730
I dont know the exact process that I have done before, however the trick is to zero your page count, and this worked twice for me. The printer figures your waste ink reservoir (actually a sponge) is near full by a page counter. There are articles out there on how to repair this physically but please dont go there, get a new printer or even better an less used MP730.
Waste ink near full
waste ink is the container that collects excess ink during cleaning cycles.
mechanicla repair, if you can get your hands on the service manual you can replace it yourself.
otherwise just replace the printer.
2helpful
4helpful
Waste ink near full
Try this Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
1helpful
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Waste ink near full
Here are the code for it
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
9helpful
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
old marine
old marine
ZJ Limited
ZJ Limited
