SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply
fails. They are very sophisticated designs that are difficult to
troubleshoot and generally best to just replace the module, but
sometimes there is visible damage in some of the electrolytic
capacitors (visibly bulged) and high voltage rated parts can be
substituted.
Hope Ya Fix It
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: hitachi ultravision projection that is turning off
your Guru didnt even know this set is a plasma, look for the main filters on the power supply, the big ones to see if the tops of them are crowned these new sets are very particular when it comes to filtering.
SOURCE: won't turn on
Hi, everyone. Me too have the same problem. TV just stays in red but won't turn to blue. I tried unplugging then wait and restart again, sometimes it will work but lately that trick doesn't work anymore. Then somebody suggested to open the back of the tv (it's not hard... just a lot of screws and a couple of bolts to remove) and clean (vacuum) the exhaust fan. Out of frustration, I did open the back and clean the the fan (has a lot of dust on the blades) and everywhere where there is dust. Just be careful not to touch any part of the printed circuit board with the vacuum nozzle to eliminate the destructive effect of static electricity. Or while you're cleaning it you have to hold the metal frame with your other hand to ground yourself (by the way you have to unplug your tv before you start opening the back). After the cleaning then covering the back, the tv worked... for only a few hours. It did stop working again as soon as I turned it off then on again. Again I opened the back, this time I removed the power supply board ( that's the biggest board and located above where you connect all your wirings). Got myselt a small brush and start brushing and vacuuming the dust out. I don't know if the cleaning did the trick or it was the unplugging of the connectors from the power supply board. All these work did the job... my tv is still working for almost three weeks now. Another thing, when you have a a time warner cable with a dvr box where you can program its remote to power most of your equipment in sequence by pressing the remote power button, I set it so that the tv will be powered up last considering that power can fluctuate everytime a unit starts up specially when they are all connected to the same power/surge protector... tv doesn't like it when the power fluctuates while it is still starting. Hope these helps.... (Hitachi 42HDS69)
