SOURCE: SAMSUMG LCD TV MODEL NO.ln-t2653h
just check whether the fuse is blown ...........
also check proper power supply is supplied to tv......
SOURCE: Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That
did it for me. After I shut it off I had to do it one more time but it
did the job. A friend of mine gave me the tv for free because nobody he
new could figure it out. I took it home, got lucky, and figured it out
in about ten minutes.
Hope this works for you.
jb
SOURCE: Bush 32" LCD 1080p tv
if the screen flickers in thin lines across horizontaly then it the progressive scan on the HD side, mine does the same so i turn the brightness and sharpness down... problem solved (for me) also mine is ok through scart 1&2, DTV (digi) and ATV (anna)
SOURCE: LHD3204US 32 in. HDTV LCD Television: I can't get any power to my 32" Hisense TV model n...
Have your checked or replaced the fuse in the plug?
