HTC EVO 4G Smartphone Logo
Posted on Jul 27, 2011
I am not able to send email from my windstream.net email. I can receive just fine. For outgoing mail- user name-same as my email address, which is [email protected] password... smtp server...I have smtp.windstream.net security type is none and server port is 25 (we attempted to change to 587 as well) I get the following error: email address is not valid. Please verify your email address [email protected] We then attempted the email address as just anders3 and received the same error.
1 Related Answer
Anonymous
  • Posted on Jan 28, 2010
SOURCE: I received mail ... but dont send ... Because smtp problem
go to your settings to change what your phone is doing
Nexicom.net email setup on ipad
You have to go into Settings -> Mail, calendar ... and add a new mail account as "Other". Put in your email address anywhere you see user name. Choose the POP type of account - IMAP won't work. Use the following for settings:
  • incoming server: mail.nexicom.net
  • user: your email full address
  • password: your password
  • outgoing server: outgoing.nexicom.net
  • user: your full email address
Tap "Next" and it will likely fail and ask if you want to connect without SSL. Tap "Yes" and you should get all green checkmarks and mail should now work. :v)
4answers
0send/receive showing 0 of 52 task completed?
hi!!!!!
may be there is a problem in your ISP
so try to resend it
or try to zip your jpegs file and then sen it to email!!!
tip
How to setup your Iphone to USA.NET email account
Here's the settings for your iphone and also to ensure the best performance and reliability of email on your iPhone, the most recent updates MUST be applied before configuring your device. These updates can be installed via iTunes. Consult your iPhone User Guide for more information.
1. From the Home screen, choose Settings > Mail > Accounts > Add Account.
2. From the email account type selection, choose 'Other' at the bottom of the list.
3. Choose 'IMAP' from the top of the Account Information Screen.
4. Enter your Name, Email Address, and a Description for the account.
5. For Incoming Mail Server:
- Enter imap.postoffice.net in the Host Name field
- Enter your Full Email Address in the User Name field (i.e. [email protected]).
- Enter your account password in the Password field.
6. For Outgoing Mail Server:
- Enter smtp.postoffice.net in the Host Name field
7. Scroll to the bottom of the screen and touch Advanced.
8. Under Settings, select ON for both Incoming and Outgoing Uses SSL.
9. Set Authentication to Password.
To checked if its working, send a test email to your email address.
on Feb 16, 2010 • Cell Phones
tip
To Set Up Your E-mail Account in Microsoft Outlook
1:In Microsoft Outlook, select Tools > E-mail Accounts.
2: On the E-mail Accounts wizard window, select "Add a
new e-mail account" and click Next.
3: For your server type, select "POP3" and click Next
4: On the Internet E-mail Settings (POP3) window, enter
your information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your e-mail address.
User Name
Enter your e-mail address, again.
Password
Enter the password you set up for your e-mail account.
Incoming mail server (POP3)
Enter pop.secureserver.net for your incoming mail server.
Outgoing mail server (SMTP)
Enter smtpout.secureserver.net for your outgoing mail server.
5: Click “more settings”. On the Internet E-mail Settings window, select
the "Outgoing Server" tab.
6. Select "My outgoing server (SMTP) requires authentication."
7. If you did not change the SMTP relay section, select "Use same
settings as my incoming mail server". If you changed the user name
and password in the SMTP relay section of your Manage Email
Accounts page, select "Log on using" and enter the user name and
password. The following example assumes you did not change your
SMTP relay section in your Manage Email Accounts page.
8: Select the "Advanced" tab and change the "Outgoing server (SMTP)"
port to 80 or 3535.
9: Click OK.
10. Click Next.
11. Click Finish.
1helpful
I am not able to send or receive my Yahoo mail. I
Hi
Follow these steps.
ncoming Mail (POP3) Server: pop.mail.yahoo.com (Use SSL, port: 995)
Outgoing Mail (SMTP) Server: smtp.mail.yahoo.com (Use SSL, port: 465, use authentication)
Account Name/Login Name: Your Yahoo! Mail ID (your email address without the "@yahoo.com")
Email Address: Your Yahoo! Mail address (e.g., [email protected])
Password: Your Yahoo! Mail password
If you want to use Outlook, Outlook Express, Thunderbird or other third party email clients to view your email you have 2 options.
Subscribe to mail plus:
http://billing.mail.yahoo.com/bm/Upgrade…
or download and install YPOPS
http://ypopsemail.com/
then follow the directions for your version of outlook here,
http://help.yahoo.com/l/us/yahoo/mail/or…
If you have trouble with set up, check the YPOPS installation page for alternate set up instructions.
http://dbeusee.home.comcast.net/
Click on YPOPS link on the left.
Then Click on Configuring email clients towards the bottom.
Choose the appropriate link for your mail client.
I currently utilize version 2.0.0.4 of Thunderbird
and version 0.8.3 of YPOPS (there is a more recent version of YPOPS that you need if you are Yahoo Beta Mail) and have no problems.
Jan 27, 2010 • Yahoo Mail
1helpful
I discontued my Yahoo e-mail service. My user
Delete [email protected] from your contacts/address book. That will stop any new occurrences.
You most likely have [email protected] as a recipient in some e-mail threads to which you still reply. Your friends are most likely doing the same thing.
Nov 06, 2009 • Yahoo Mail
2answers
When I tried to send email from Outlook, the Internet Service Provider replied -ERR [AUTH] invalid user/password. How can I correct this error?? My ISP is att.net. I have not found a solution on that...
This means that your user/password combination is wrong for that email server. So double check that you have the right password and user name entered for that account in Outlook. If you're 100% sure you have it right, then you might be using the wrong email/authentication server. If you continue to have problems and are located near Washington DC, feel free to contact me through my website.
Nov 03, 2009 • Yahoo Mail
1helpful
2answers
I need help setting up my email on my iphone
1) If this is the first email account you're setting up on your iPhone, tap Mail. Otherwise, from the Home screen, tap Settings.
2) On the Settings screen, tap Mail.
3) On the Mail screen, under Accounts, tap Add Account.
4) On the Add Account screen, tap Other.
5) Select POP and then enter your account information using your keypad. Name Enter your name. Address Enter your email address. Description Enter a description of this email address. The description displays in your email account list on your iPhone. 6) Enter your Incoming Mail Server information.
Host Name Enter pop.secureserver.net. User Name Enter your full email address as your user name. Password Enter your password for your email account. 7) Enter your Outgoing Mail Server (SMTP) information.
Host Name Enter smtpout.secureserver.net. If you need to change your port, use one of the following for your outgoing mail server, depending on the port you want to use:
smtpout.secureserver.net:25
smtpout.secureserver.net:80
smtpout.secureserver.net:3535
User Name Enter your full email address as your user name. Password Enter your password for your email account. Note: The user name and password for your outgoing server is the same as the user name and password your entered for the incoming server.
8) If SSL mode is enabled, under Outgoing Mail Server (SMTP), tap Advanced.
9) Set Incoming Uses SSL and Outgoing Uses SSL to OFF.
9helpful
2answers
Pop email settings with godaddy domain
I FINALLY GOT THE ANSWER! I ALSO HAVE A GODADDY EMAIL ADDRESS AND USE A HTC TOUCH PHONE FROM SPRINT. I've entered the following settings and my email now works like a charm! This is for a POP3 email address, not an IMAP email address.
You cannot send the email unless you have a sprint email address. Email must go through the Sprint server in order to be sent (incoming mail does not).
Call Sprint Tier II (877.345.7895) and ask them to set you up with a User Name and Password for the outgoing mail server. All the rest of the settings are as follows:
EMAIL SET UP Email Address: [email protected] Your Password: the password you use to access your go daddy account Check SAVE PASSWORD Click NEXT UNCLICK TRY TO GET EMAIL SETTINGS AUTOMATICALLY FROM THE INTERNET. Click NEXT. Your Email Provider: Internet Email Click Next Your Name: Dales Wife Account Display Name: 'GoDaddy Email" or whatever you'd like to call it so you can identify this account (you can have several email accounts sent to your phone). Click NEXT Incoming Mail Server: pop.secureserver.net Account Type: POP3 Click NEXT User Name: Again enter [email protected] Password: Enter your password again Check SAVE PASSWORD Outgoing (SMTP) Mail Server: smtp.sprintpcs.com CHECK Outgoing server requires authentication UNCHECK Use the same user name and password for sending email Advanced Server Settings: DO NOT Check: Require SSL for Incoming e-mail DO NOT Check: Require SSL for Outgoing e-mail Click DONE to return to previous screen Click NEXT Outgoing Server Login: [email protected] Password: When you call Sprint Tier II they will ask you what password you'd like. Check Save Password. Automatic Send/Receive: I use every 5 minutes and it doesn't seem to run my battery down. Click FINISH. This has been driving me crazy for two months now so I really hope this information helps somebody else out. Best of luck! NOW, if anyone knows how to remove those annoying envelopes when I access my mail - I could use the help. There are three envelopes there (one for GoDaddy mail, one for Outlook and one for Picture Mail.) I do not use Outlook or Picture Mail and would love it if I could remove those.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
