Apple iPhone 3G Logo
Anonymous Posted on Aug 30, 2008
Honeywell Wireless Personal Weather Station TE109NL is not working. I have changed the batteries.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
77
Points
Both units (transmitter and receiver) require two AA batteries. That solved the problem!
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
How do I reset the time on my smartgear weather station
I have two of these and they lose the signal occasionally. Per the manual: Make sure all batteries are good and then press the TX button on the remote sensor for 3 seconds so it sends a wireless signal to the weather station. It should beep. Then on the weather station hold the CH button for 5 seconds to make it search for the transmitter until the outside temp appears. Just removing batteries and reinstalling them in various orders doesn't work. You must re-establish the wireless connection between the outdoor sensor and weather station.
I need a manual for Honeywell Atomic Clock wireless weather station Model # TE322W-EL-NL
I did a search and could not find anything on that particular model. But I found some things that may help.
Here is a link to a manual for a different weather station by Honeywell that may help. http://www.honeywellstore.com/store/images/pdf/TE242ELW.pdf
If not try their support section:
https://honeywell.com/Pages/contact-us.aspx
1helpful
Reset oregon scientific weather station
I always have trouble getting mine to work after changing the batteries, but I have just managed to get it going by doing the following:
taking batteries out of main unit
putting new battery in remote unit and pressing remote unit reset button
re-inserting batteries in main unit and pressing reset button.
i think the trick is to ensure that the batteries go in the remote unit first, then the main unit after that. It has taken me days to work this out!
Honeywell weather station manual te657w
Hi i need the manual for the above is there some where u could upload the manual to and give a link thanks
1helpful
3answers
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
