It sounds like your battery is bad. They can be replaced readily easily. Batteries an be found on eBay for as little as $5 and directions to replace it can be found here: http://www.ifixit.com/Browse/iPod
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
i
got an i-pod NWZ-B152F of sony.after connecting to P.C it starts
charging but P.C does not recognise it.i want to transfer songs from my
computer to i-pod.can you please help?
Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:
The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (
Figure 2: Example USB connection (your product might not look exactly the same as this example)
Remove the cartridges from the product.
Wait for the 'Insert Cartridges
' message to display on the control panel.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button (
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
Restore and it'll download ~240mb firmware and you're done
Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
USB cable is connected between PC and Mobile, Charging is happening. Modem drivers installed. Mobile phone is displayed having Sychronising, phone book, calendar, text message, multimedia studio. On this "initialisation....please wait" is displayed and after some time it displays "mobile not connected".
Generally speaking, if you have connected it to a power source when it has completly drained it should display 'Please Wait, Very Low Battery' (without the backlight). If it does, leave it until that message disappears. Pressing the play button should now wake it. However, If you have been charging it for a while and nothing has been displayed the battery my be dead all together. With the iPod connected press the Select and Menu Buttons together until an Apple symbol appears (non-backlit) it should then startup. If it turns off when disconnected from the power then you have a dead battery. If none of that solve it I offer a repair service at a very low cost.
1. Remove battery from phone, and unplug from charging cable 2. Unplug Phone base 3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base. 4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen. 5. Press 0 6. Unplug power from phone pod 7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen. 8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button. 9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support. 10. Replace Battery 11. Make a test call
