http://www.lacrossetechnology.com/eh23sa/manual.pdf Hi Bill click link this will explain in detail your question i think you will find it is automatic and sets itself ..but check instructions will tell you hope this helps
This is the model with the exposed button on the right side. The back does not come off, but the front does! If you use a loop you may be able to see a notch between 7 and 9 O'clock. Be very careful because the gasket keeping the watch water resistant is right there. You do not want to harm it. I put the watch in a holder and place a very thin jewelers screw drive on the side. With a jewels hammer I tap lightly until the front comes off. You must then carefully remove the movement from the case and not touch the hands. In order to close the watch after battery replacement, a watch press is a must. Without the press, you won't get the watch closed. The manufacturer suggests taking the watch to a qualified professional. You can send it to the manufacturer as well and they will change the battery for you. The Manufacturer is La Crosse Technology in La Crosse Wisconsin.
No, just set properly. This watch is very difficult to set. A watchmaker may be able to help you. The instructions are not very clear. You might try a watchmaker for assistance or try calling them although I have not had much luck along those lines.
you can get the crystal off, but not back on. There is a special tool that is used to compress the crystal to make it fit in the bezel. Besides, if a piece chipped off, it is no longer waterproof. Take it to a jeweler and he can put a new crystal on in no time. Crystals are not expensive.
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
