To fix your
micro-sd card you can use the program which you can download by clicking
here.
After
downloading the file run it in your PC and format your
micro-sd card. Windows file manager can not read the card but this software exactly can format it. But if you format the
micro-sd card all the file in it will be deleted.
Do the followings to format it:
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file in your PC.
You will see the menu below:
- Select the device which you will format.
- Select the file system FAT32,
- Give a volume name.
- If it is checked uncheck the quick format option. And the other options will be unchecked.
- Click the Start button to begin formatting.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
