Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Posted on Jul 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hln5065w started making a loud noise like a fan noise upon startup recently. The color is fine (I've read the color wheel w/loud noise problems). It has been doing this for the past week, previously I have had a complete replacement of the light engine and after the not so good local repairmen got that back together it worked but all of the inputs except one failed, but that has been the case for years as I was told that a new board was $600 plus labor to replace.
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Jul 21, 2011
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2823161
Points
26282
The loud noises came from the tv with a colors wheel design in it have to be replaced every few years,because the spinning of the colors wheel disc are spinning in very high speed in RPM to have it colors for the tv to operate correctly,the humming,loud motors noises and eventually the effect of the tv colors.The colors wheel disc are worn out and spinning hitting it axes motor,the colors wheel must be replaced to solved this problems.
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
1helpful
My Samsung HLP6163W started making a loud buzzing sound and the picture is distorted. I've read around and have come up with two possible solutions: replacing the lamp or replacing the color wheel. ...
100% this tv problems it is the tv colors wheel it is defective require replacing.The loud tv buzzing noises sounds are the sounds came from the tv wharp colors wheel it is spinning out control wildly and off of it motor axis and by hitting it to the wall of it steel box holding it.The tv distorted colors pictures are came from out of the reflections of a badly worn out of the tv colors wheel.
2answers
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
5helpful
2helpful
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
TV makes a loud whizzing noise from back. Could
The color wheel or fan can cause that. However if its a very loud soind its most likely the color wheel as it spins very fast.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
