Jakks Pacific Spy Kit Logo
Posted on Jul 14, 2011
My spynet video watch is dead and evertime i pug it in it says battery charged.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
611
Points
Get ur USB and plug it up to the computer and and then plug it up to ur watch, and the computer has to be on, so play on the computer for a while and then it should be charged if not then u should return it or buy a new one.
What other chargers for Spynet watch that work?
All you need is a mini-USB to USB cable. Then use your laptop or any open USB port to charge.
My spynet video watch won't charge.
If you have a Iphone charger base unplug the wire then just cilp in the long retangular part of the usb charger (also works with a nitendo charger) then plug itno the wall connected to the watch. not everyone needs a computer used to charge it!
2helpful
How do you fix your volume on a spynet video watch
The speaker is dead you need to go ask the person you bought it from.
3helpful
My son's spynet watch has stopped working. Have tried to charge it using different usb, but not even registering as plugged in on the computer. Anyone else had this problem? Think will have to return it,...
Hi there we had to take back his first spynet watch because the speaker decided not to work then we took back a second spynet watch because it would work when it felt like it...our son really liked it too, however after the second watch we didn't wan't to keep having problems so he decided to buy something else...gave up trying to get on their website because it kept freezing and couldn't download spy missions so we had nothing but problems with it ...hope that helps
I bought our son a Spynet Video watch for Christmas and we charged it but when we removed it from the charger, it turned off and wouldn't turn on. I then thought maybe we needed to download some kind of...
A bit late to the party, but two things come to mind. If the watch is new old stock with a few years on it, more than likely the battery is bad, it won't charge any more. Also, the power supply may be bad, I use 5 volt one amp charger, also, the manual says to charge it with the screen on, I tried that, and the battery will never be fully charged because the screen being on drains the battery faster than the charger can charge it.If the watch is working but the battery is low, connect the charge cable to the watch, then to the charger, otherwise the charger will pull the battery down too. So, let the screen go blank, then charge it, I have tried this method multiple times, and every time, assuming the battery is good, it fully charges in few hours. If you are adventurous, you can upgrade the battery to 450mah, it's a little bigger than the one it comes with, but lasts a lot longer, only a small amount of modification to the plastic strips made into the watch back need to be done, simply remove the strip closest to the electronics and it will fit just fine.
My son got a Spynet Video Watch for Christmas. He has been charging it for over 5 hours and it still doesn't show a full charge. It only shows half a charge and when he takes it off and tries to use it...
Hello, Pdschanz -
Since the watch was a Christmas gift, it is probably still under warranty.
I hope you found and downloaded the instructions for the watch, saved them in a Documents file with a file name you can find again easily, printed the instructions, and read them thoroughly all the way.
If you have not yet contacted Customer Service for the watch, I suggest you do that after reading through the instructions and the FAQs near the end of the instructions.
This is the telephone number for Customer Service for Jakks Pacific Inc., manufacturer of the watch:
877-875-2557
Malibu, California
Call weekdays during normal office hours, Pacific Time zone.
This is the email address for Jakks Pacific Customer Service:
[email protected]
Source of information:
Instructions for Spynet Video Watch with Night Vision
http://www.spynethq.com/core/pdfs/instructions/Video_Watch_with_Night_Vision.pdf
Best wishes.
7helpful
3answers
Spynet Video Watch not working - battery was removed fine but will not charge properly and have to change time and date everytime plugged in USB slot again to charge. Is this just a piece of **** I should...
OMG!!! I am so upset right now my son's watch was on the computer charging and now all it has across the screen is spynet ....I HAVE RESET IT AND IT GOES BACK TO THE SAME THING!! I AM RETURNING IT TODAY!!! WHAT A DISAPPOINMENT
Dec 26, 2010 • Toys
Top JAKKS Pacific Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
