Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start point for troubleshooting, and can sometimes mislead.
Error P1 is 'not enough water to operate the unit:'
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
This problem can be caused by plumbing problems such as crossover, or clogged water lines, or dirty water filter, or clogged water softener, or temperature of unit set too high. Or combination of these problems.
Remember if temperature is set very high, then more cold water is used at the faucet. This means less hot water is drawn through the tankless water heater, so the flow rate may drop below activation threshold.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
