Garden Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water in the oil - Northstar Garden
Ron
Level 2:
Sergeant:
  • Expert 195 Answers
  • Posted on Jul 06, 2011
Ron
Expert
Level 2:
Sergeant:
Answers
195
Questions
0
Helped
74487
Points
556
Bad Ju-Ju. this can mean that water is leaking past the plungers. try removing all the oil and replacing it then see if and how much water is in there.
1helpful
3answers
Oil/water out of block breather
Sounds like it could be a blown head gasket or a cracked water jacket I would advise draining oil and watching for signs of water in the oil secondly if you find no signs of oil in the water erase sale and out of pressure pump to the system if the problem can says if the problem continues as a temporary fix you can run a bottle of copper block sealer through engine remember though that it's only a temporary fix
2helpful
Engine mixing water and oil in the sump. took the cylinder head and engine block for pressure test. but still mixing what could be wrong. The above was returned as not cracked.
hi there.
Water in the engine - Water can get into your oil sump in two ways: ... Water in the oil- Coolant leak due to non-watertight seal (cylinder head gasket, etc.). If this happens, there is a leak and water is getting into the oil.
Water in engine oil
If you found water in oil car , this water engine car section is for you!
Water in car engine? Water should never be allowed to get into the oil in your engine or gearbox. Otherwise, it will result in significant foaming, dramatically reducing the product's lubrication properties.
  • Water in car - Water condensation in cold air or combustion gases: this phenomenon is extremely rare and only occurs at specific temperatures.
  • Water in the oil - Coolant leak due to non-watertight seal (cylinder head gasket, etc.). If this happens, there is a leak and water is getting into the oil.
Water in motor oil can cause serious damage to your engine - the oil will be denatured and no longer effectively cooled.
Contact your repair centre as soon as possible.
1helpful
Water get into oil
Water in oil makes the oil go grey / milky or white . Check the cooling system by a pressure test and if it is holding then it will not be water in the oil.. If you are referring to transmission oil then the tan colour indicates burnt oil, and must be replaced. Water in that oil will also be a white cherry/ milky colour.
4helpful
2answers
Refrase 1996 hyundai excel ,oil in water no water in sump oil.
Oil in the water is usually a sign of a head gasket leak, because the high pressure oil passes through to the head in order to lubricate the camshaft.
The oil return passages also go through the head gasket, but are too low pressure to usually cause any problem.
As long as there is no water in the oil or loss of water, I would keep driving it.
The oil in the water will not hurt anything. If it eventually gets worse and leaks water, then you will have to do the head gasket. Costs about $500.
Of you can do it yourself for about $75 if you know how to use a torque wrench.
1helpful
1993 camaro V6 3.4 lt water and oil mixing could it be water pump
Yes there is another way, someone can be messing with your head and pouring water in your oil cap. Do have water in your oil or oil in your water or both? A product called sea foam does a miraculous job at getting water out of oil. As far as keeping it from happening further, the cheap way of course is "bar's stop leak" but man can this stuff do a number on clogging your heater core, even if they say it doesn't, it can happen.
Perkins 7.5 gen. I am getting oil in the water ,
your water jacket in the block has a pin hole in the block and the pressure of the oil versus the water is higher and forcing oil into the water you need to put dye into the oil and water and trace the leak,then "magnaflux" the block and repair it
Had water pump changed on 2003 Highline Jetta 1 month ago. Oil cooler had to be replaced 1 month later. Oil landed up in water - oil totally empty. Temperature gauze said "Check coolant". Muddy consistency...
sorry to be the messenger of bad news but from the symptoms described it sounds like the head gasket ,the oil feed to the camshaft to be more precise ,its forcing oil into the water circuit but the water is not getting into the oil because its at a lower pressure .
3answers
Leaking both oil and a mixture of oil and water
well when you have water and oil both leaking it most of the time means a head gasket or in your case a jug gasket
Top Northstar Garden Experts
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Northstar Garden Expert? Answer questions, earn points and help others
