SOURCE: I cant fold down my quinny speedi sx, i hold the
hi....i had the same problem but eventualu figured it out ...
put the footbrake on
remove the canopy
push the bar beside the hand brake and then firmly push the the pram downwards it should shut..
it is a bit tricky at first but u'll get it eventualy...
smaira
SOURCE: Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
SOURCE: how do i fold down my quinny buzz
Hi you need to apply the brake 1st. then stand at the front, there is 2 grey buttons either side of the seat on the 2 round bits. 1 you push down the other you slide forwards, keep hold of them & pull it downwards towards your feet. This will then fold down.
SOURCE: I have broken the fold
It needs to be sent to the engineers for inspection and repair work required. If you are a UK resident contact 01284 413 141 Mon-Fri 8.30-4.30 to book it in. Standard cost is 72GBP and includes courier collection and delivery.
