More than likely you have an internal fault either in the fan itself or the thermostat that activates it.
For a fuse to blow it has to have a lot higher than normal current draw through it, which is normally refered to as a short. If the fuse blows almost immediately then I would suggest you unplug the fan, and see if the fuse blows with just the thermostat in the circuit. If it blows - replace the thermostat control. If it doesn't blow, plug in the fan and watch it. If it trys to start and then blows the fuse, replace the fan motor.
