Dell Streak Smartphone Logo
Posted on Jun 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I am turning on the bluetooth this error message appears "The application Settings (process com.android.settings) has stopped unexpectedly. Please try again."
Alon C.
Level 2:
Habit-Forming:
New Friend:
  • Expert 69 Answers
  • Posted on Feb 03, 2018
 Alon C.
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
69
Questions
Helped
7884
Points
100
5 Related Answers
Anonymous
  • 1768 Answers
  • Posted on Apr 22, 2010
SOURCE: trying to remove win32 trojan and inadvetently
If you have enough hard drive space you may be able to load Windows on a new partition and load windows then download a anti virus protection such Windows Essentials or Avast Home edition ( free) work well and the scan you drive.
Sometime it works sometimes it doesn't depends on the virus.
All else fails is to fully clean the hard drive and start over.
I hope this helps!
You may want to use another PC to get the anti virus downloads and install them.
Anonymous
  • 2229 Answers
  • Posted on Jul 30, 2010
SOURCE: I can't get into windows
You most likely have a hardware issue. Very possibly memory.
You'll need to troubleshoot that by disconnecting everything in the case but the video, CPU, and memory and see if it starts OK.
Then hook up the hard drive and see if you can boot into Windows. If you can't, unplug one of the memory sticks and try it. Then the other memory stick and try.
If you have a Windows startup (installation disk), boot from that and opt for system repair. You will want to get to the command prompt and run chkdsk.
See my tip here:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
Testimonial: "I am not a computer technician so I am unable to do what you suggest. Any idea whee I could get help?"
Anonymous
  • 1555 Answers
  • Posted on Aug 20, 2010
SOURCE: Hi, My laptop doesn't boot up. I got a blue screen
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
Anonymous
  • 689 Answers
  • Posted on Sep 09, 2010
SOURCE: Dell Inspiron mini - received
reinstall your OS from disc this should cure this problem
Walter H Boehm
  • 998 Answers
  • Posted on Feb 07, 2011
SOURCE: Blue screen error STOP: c000021a
It appears that your Windows Registry is corrupted. You can try to use a Registry repair utility like CCleane to fix it. If that doesn't work you will have to reload Windows OS (Operating System). For more info no this error code Google "c000021a".
Android problem
Upgrade ur samsung using samsung kies it will be safe ur data
LG GT540 Cell Phone "sorry the process com.android.phone has stopped unexpectedly. please try again"
Ok, I would say to reset your phone by code, just dial
  • Dial 3845#*54#
  • Now select Factory reset
But obviously it won't work because Android is corrupted.
I will leave this link which will explain how to hard reset your phone without using Android, and I hope it works. Hard Reset LG GT540 Swift
The process android.process.acore has stopped unexpectedly. please try again keeps appearing not allowing me to do anything but turn it off what do i do
I would preform a factory reset (note: this will erase all messages, contacts, settings, apps, etc.). To do a factory reset, go to: 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
I hope this helps!
1helpful
Hi, I bought Smart Epad 7" I had error of The
You can restore your epad to factory settings by going to the settings menu > privacy > Factory data reset. and then your epad should be running normally again.
Top Dell Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Dell Cell Phone Expert? Answer questions, earn points and help others
